Fibaro Roller Shutter 3 FGR-223 V5.1 - Does not work
I installed a Fibaro Roller Shutter 3 - Firmaware v5.1.
(I used Zwave even though it is depreciated because ZwaveJS does not take the Fibaro module yet).
The calibration since Hass has worked well. The roller shutter moved up, down and back.
But, when I click on the top arrow (on Hass), nothing happens.
If I press the switch on the wall, I do have the status change on Hass and the power consumption is displayed.
After about 15-20 minutes, the status changes from “Ready” to “dead”.
The parameter is failed passes from False to True.
What should I do to use the roller shutter from Hass ?
I used switch to open the roller shutter.
It was “Ready” on Hass. After less than 5 minutes, the module is “Dead”
Anyone using this device with ZwaveJS currently? I’ve got it installed, which resulted in TWO entities for cover.markis_XYZ, and TWO switch.markisXYZ ??
What are the purposes of the switch entities?
My main problem is of course that pressing one (or the other) the cover-entity in lovelace, does NOT seem to provide any power to Q1 or Q2?
