Hello, I’m using file integration with timestamp set to true. The problem is that the time is 1 hour minus the real time in my zone (Italy). The external time or the time in terminal, is correct. How can I modify the timestamp in the notify file?
The timestamp is in UTC not local. If you want local you can add your own. Disable the timestamp option and do this:
message: "{{ now() }} your file message here"
You can format it however you want. See: The EPIC Time Conversion and Manipulation Thread!
Thanks for your answare!. Solved my problem, but could be great modify the timestamp format from the integration… Thanks again
