Team:
I migrated from using a Python Virtual Environment on a NUC to Hassio on a RPI4 with a SSD over USB. I settled all of the conflicts with the other components. The only one that I cannot get to work is Lutron Caseta. I always get the error:
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/__init__.py", line 71, in async_setup_entry
bridge = Smartbridge.create_tls(
File "/usr/local/lib/python3.8/site-packages/pylutron_caseta/smartbridge.py", line 106, in create_tls
ssl_context.load_verify_locations(ca_certs)
FileNotFoundError: [Errno 2] No such file or directory
I first tried putting the certificates in the /config folder and using this configuration, but it didn’t work:
lutron_caseta:
- host: 192.168.1.108
keyfile: caseta.key
certfile: caseta.crt
ca_certs: caseta-bridge.crt
I also tried to find the full path of the /config folder using SSH and tried use that, but it didn’t work. Is there anyone running hassio with Lutron Caseta component (non-pro) can show the file path that they used, that would be helpful.
Thanks in advance.
