File sensor does not show up in entities
hello,
i just created a file sensor
- platform: file
  file_path: /config/tmp/reset-lg-devmode-timer_result.txt
  value_template: "{{ value_json.result }}"
but it won’t show up in entities.
and when I try to read the state like this
{{ states('sensor.lgdevresult') }}
it returns unknown.
So I doubt this one works.
What should I do to make this file sensor work?
If the value json does not resolve, the sensor will not exist.
Did you check logs?
I actually needed to restart HA core fully, not only “quick reload”
