Currently, when you use labels to filter automations, it is possible to select several labels, but the filtering is applied according to an “OR” logic. For example, if I select the “In service” and “Water” labels, the filter displays all the automations that have either the “In service” or the “Water” label. This can be useful in some cases, but in other situations, I would like to be able to see only those automated systems which have the two labels selected.
I therefore propose adding a toggle switch to the filter interface, allowing you to choose between an “AND” filter (automations with both labels) and an “OR” filter (automations with one or other of the labels). This would offer greater flexibility and precision in the management of automations.
Thank you for your attention and for considering this suggestion!
