Filtering entity state in template
Hi, in a template is it possible to filter/exclude 2 states of an entity?
- name: "Heating State"
      unique_id: "heating_state"
      icon: mdi:fire
      state: >
         {% if is_state_attr('climate.smarther_thermostat','hvac_action','idle') %}
           INACTIVE
         {% else %}
           ACTIVE
         {% endif %}
When the entity “climate.smarther_thermostat” becomes unavailable or unknown, the template returns the ACTIVE result.
Is it possible to ignore these 2 states in the template? Or alternatively, that the unknown/unavailable state returns INACTIVE instead of ACTIVE.
The best practice is to define an availability:
      icon: mdi:fire
      state: >
           INACTIVE
         {% else %}
           ACTIVE
         {% endif %}
      availability: "{{ has_value('climate.smarther_thermostat') }}"
But, if you prefer it to return INACTIVE when the climate entity is unavailable, you can use the in test against a list:
      icon: mdi:fire
      state: >
         {% if state_attr('climate.smarther_thermostat','hvac_action') in ['idle', 'unavailable', 'unknown', none] %}
           INACTIVE
         {% else %}
           ACTIVE
         {% endif %}
Ok, thanks.
Can I also use the second solution, setting the availability as well?
Or is it not necessary?
You can, but it is redundant… the availability template is checked first, if that passes then the state template is rendered.
Thanks, it works perfectly.
Is it also possible to add a hysteresis to this sensor? For example if ACTIVE for 3 seconds…
Not as it is currently configured.
Options:
  1. Switch to a trigger-based sensor and use triggers that have defined for values.
  2. Switch to a binary sensor so you have access to the delay_on configuration variable.
I tried binary sensor, but it is not suitable (I need named states as I say).
I have to study the sensor with the trigger, I’ve never made one. What do you recommend?
The first thing to do is to create a sensor that mirrors the value of the hvac_action attribute of your climate entity. This is necessary because attributes do not have an independent way to track when they change.
  - name: "Smarther HVAC Action"
    unique_id: "smart_ther_hvac_action_0001"
    icon: mdi:fire
    state: "{{ state_attr('climate.smarther_thermostat', 'hvac_action') }}"
Then you create a trigger-based sensor that watches that sensor’s state and with a 3 minute duration on the “ACTIVE” trigger:
  - id: INACTIVE
    platform: state
    entity_id: sensor.smart_ther_hvac_action
    to:
      - idle
      - unavailable
      - unknown
  - id: ACTIVE
    platform: state
    not_to:
      - idle
      - unavailable
      - unknown
    for: "00:03:00"
    icon: mdi:fire
    state: "{{ trigger.id }}"
