Temperature, how to use outlier filter?
I have an Aeon Labs Multisensor 6 that I use to read temperature. It reports this value every 10 minutes. Any time I restart HA, it produces a report of 0 degrees. I want to plot the temperature without the zeroes, so the new outlier filter should be useful.
I can’t get it to work however. My new filter sensor reports 0.0 regardless of what parameters I use for the outlier filter.
Configs:
#Sensors
  - platform: yr
    monitored_conditions:
      - temperature
      - humidity
  - platform: filter
    name: "filtered temperatur"
    entity_id: sensor.aeotec_zw100_multisensor_6_temperature
    unit_of_measurement: '°C'
    filters:
      - filter: outlier
        window_size: 20
        radius: 7.0
#History_graphs
  temperature2:
    entities:
      - sensor.aeotec_zw100_multisensor_6_temperature
      - sensor.filtered_temperatur
      - sensor.yr_temperature
    hours_to_show: 72
    refresh: 120
History graph:
temp
Additional question: Is it impossible to make the filter sensor use the previous data? I.e. have values instead of the grey bar saying unknown.
EDIT: I have tried to change window_size and radius, but it just gives me zeroes anyway.
No one using the filter sensor function?
Hi!
https://github.com/home-assistant/home-assistant/pull/13075
Will hopefully fix your issue :slight_smile:
Hello, and thank you!
Will the fixes be included in the next update of HA, or is there something else I can do to get them in now?
I’m still waiting approval and considering the changes involved I would wait :slight_smile:
Alright, waiting for the next update of HA then. Thanks. :slight_smile:
I think there is something wrong with the history graph component. All of a sudden my regular line graphs for temperature and humidity (non-filtered values) turned into bar graphs, showed above the line graphs. unit_of_measurement is set correctly and it worked this morning, but not now, with no restarts in between.
Very weird…
EDIT: After 45 minutes, the bar is gone and the line is back, without me doing anything. :thinking:
Are these changes in the beta version that just was released?
No, still waiting approval:
It’s already in the beta version :slight_smile:
Is this change active in the current version? For me it doesn’t look that way…
Has been since version 0.68.
Can you describe your issue ?
nevermind, looks like i had an error in my sensor data
