🎉 Finally! Native JSON API from REC BMS WiFi module for Home Assistant integration
Hey folks,
After (… a lot of …), I’ve finally uncovered how to natively integrate the REC BMS with Home Assistant using its built-in JSON API! This works with the optional WiFi module.
Key discovery:
The WiFi module exposes a REST endpoint at:
http://<your_wifi_module_ip>/cell
returning a comprehensive JSON structure with all essential BMS data.
API response structure:
  "bms_array": {
    "master": {
      "time_remaining": "...",
      "st_naprav": ...,
      "mincell": ...,
      "maxcell": ...,
      "ibat": ...,
      "tmax": ...,
      "vbat": ...,
      "soc": ...,
      "soh": ...,
      "erro": {
        "present": 0,
        "addr": 1,
        "st": 0,
        "con_st": 0
    "slave": {
      "0": {
        "temp_bms": ...,
        "temp": [...],
        "res": [...],
        "nap": [...]
Implementation steps:
  1. REST Sensor Configuration (YAML):
# REST sensor to fetch BMS data
- platform: rest
  name: BMS Master Data
  resource: http://[BMS_IP_ADDRESS]/cell
  scan_interval: 60
  json_attributes_path: "$.bms_array"
  json_attributes:
    - master
    - slave
  value_template: "{{ 'OK' if value_json.bms_array.master.error == '' else 'ERROR' }}"
  1. Template Sensors (Partial YAML example):
# Voltage/Current/SOC
  sensors:
    bms_master_vbat:
      friendly_name: "Battery Voltage"
      unit_of_measurement: "V"
      value_template: "{{ state_attr('sensor.bms_master_data', 'master')['vbat'] | float }}"
      device_class: voltage
    bms_master_soc:
      friendly_name: "State of Charge"
      unit_of_measurement: "%"
      value_template: "{{ (state_attr('sensor.bms_master_data', 'master')['soc'] * 100) | int }}"
      device_class: battery
# Cell voltages (Slave 0)
    bms_slave0_cell0_voltage:
      friendly_name: "Cell 0 Voltage"
      value_template: "{{ state_attr('sensor.bms_master_data', 'slave')['0']['nap']['0'] | float }}"
# Temperature monitoring
    bms_slave0_temp_bms:
      friendly_name: "BMS Temperature"
      unit_of_measurement: "°C"
      value_template: "{{ state_attr('sensor.bms_master_data', 'slave')['0']['temp_bms'] | float }}"
cheers
Mikel
Hi, I developed a custom integration to use the data from REC BMS via Websocket: tiagonmas/recbms: This is a home assistant custom integration to surface REC BMS (Battery Management System) information
