I setup Nginx Revers Proxy Manager on my Raspberry Pi 4 / Home Assistant OS
my configuration file :
http:
server_port: 8443
ssl_certificate: /ssl/origin.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 5
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
I need to add the local dockers IPs but I can’t figure out how …
using the SSH add-on and running docker network ls won’t work.
I having a lot of error in my core logs like
WARNING (MainThread) [asyncio] socket.send() raised exception.
but also
2021-04-14 17:48:50 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 172, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 43, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 234, in async_handle
await self._writer_task
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 82, in _writer
await self.wsock.send_str(message)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_ws.py", line 300, in send_str
await self._writer.send(data, binary=False, compress=compress)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_websocket.py", line 687, in send
await self._send_frame(message, WSMsgType.TEXT, compress)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_websocket.py", line 656, in _send_frame
await self.protocol._drain_helper()
File "/usr/local/lib/python3.8/site-packages/aiohttp/base_protocol.py", line 87, in _drain_helper
await waiter
File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 935, in _write_ready
n = self._sock.send(self._buffer)
BrokenPipeError: [Errno 32] Broken pipe
2021-04-14 17:52:05 WARNING (MainThread) [homeass
Before I had some error like this
2021-04-14 10:34:31 WARNING (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from untrusted proxy 172.30.33.7, headers not processed
so I first add 172.30.33.7 in trusted_proxies then I add the subnet in case (172.30.33.0/24)
how can I know what IP NPM add-on is using ? and can I assign a static IP instead ?
in the multicast log
mdns-repeater (6): dev eth0 addr 192.168.3.46 mask 255.255.255.0 net 192.168.3.0
mdns-repeater (6): dev hassio addr 172.30.32.1 mask 255.255.254.0 net 172.30.32.0
192.167.3.x is my IoT VLAN where my home assistant is, but then what is 172.30.32.1? (which is outside the subnet I just added to my proxy)
also where can I add a special config for ngnix and is there some sample ? I’m new to Nginx, I would like to add more stuff but I’m not to sure how.
