Finding a way to connect my Hager thermostat
i’m renting an apartment and there is a thermostat that communicate with a valve to open or close the heating, it’s an hager EK560 https://catalogo.hager-bocchiotti.it/prodotti/prodotti-hager/building-automation-e-serie-civili/automatismi-per-edifici/gestione-riscaldamento/cronotermostati-digitali/ek560/5815.htm
from what i can see the thermostat communicate with the valve via radio 868,3Mhz, i don’t know if there is a standard to communicate from the thermostat to the valve, but i would like to be able to control the valve from HA, as i’m renting here i can not do any major changes, so anyone know what solution i can use to achieve this ??
thanks
