Well, this is a bit of a dumb question, but after weeks i cannot find a solution. Maybe someone can help me see the light lol
So every day at six in the evening one of my speakers makes an announcement: some bell - “someone is hungry” (tts) ) some bell.
I can no longer find where this is code, so far I have tried:
manually looking through all my automations and running them all: nothing. same for scripts, sensors, … (you never know)
looked into node-red nothing there
took a local copy of all my files and searched inside the content for the words used in the tts. When I try other words, it finds them just fine in yaml and other files.
listened to all files in the tts dir, but nothing there
the log only output that the speaker has changed state. It does not mention an automation, as it does when another automation triggers it. For example in the morning it logs “lights” turned on by “morningroutine” automation.
I even checked the Google Home and Smartthings apps, but no “routines” in there neither.
I am enjoying myself with home assistant and doing/testing a lot of thing so it is probably my doing, but I just cannot find it.
Based on my snapshots, the latest things I have been doing are: android ip_webcam, lannouncer (no output found to google speaker there), eufy cam integration, sensitive_Strips setup …
I realize this is a bit of a strange question, but maybe someone had a similar experience and give me the golden tip.
I would probably try and rule out each “hub” one at the time.
So just before it should announce switch off Home Assistant.
If that didn’t work try logging out of Google Home tomorrow.
And hopefully you should figure out what hub to look in
It sure is funny. It is the speaker in the kitchen and it starts when my wife is about to start cooking
Thx for the tip I will try shutting down home assistant tonight. I am not sure how to logout in google home yet, will look in to that. Hope I dont have to unlink accounts
But this thread actually made me think how easy it is to inject these kind of automations to people’s HA.
I mean if I share a json of a sequence to you and you copy paste that to node red.
All i have to do is to add a inject node and call service at the bottom right corner and nobody will notice it.
Hi all, just wanted to say thx. After weeks I have finally found it, it is
NOT home assistant automation …
NOT Google Home Routines
NOT Smarthings automations …
It was a so called “family bell” which is an option in the google assistant (not google home!)
Yesterday, I finally found the ghost Thanks all for helpin!
