Fire script from Node-RED based on variable
Hi All,
I’m trying to start a HA script from Node_RED where I use a variable to determine which script to start (new_button). new_button is part of the node message and is working fine.
I created this:
The data field looks like this:
    "entity_id": "media_media_settings_mode_{{new_button}}"
new_button contains the name of the HA script to start. I don’t need any other data fields for the script.
When running no errors are thrown, however Node-RED says: switch_turn_on called at…
I know this way of doing things works for input_booleans, but does not seem to work for scripts, or more likely I’m doing something wrong.
Config: Home assistant core with Node-Red add-on (v7.0.0)
Thanks in advance,
Ralph
