The existing integrations did not have the features I wanted or expose most of the data… this one exposes everything (except history) and has some cool features, like ‘Auto-Detect when on the LAN’
ENJOY!
FireBoard Integration
A Home Assistant custom integration for FireBoard wireless thermometers and the FireBoard Drive fan controller. It surfaces every probe temperature, battery/WiFi/device diagnostic, cook session, and Drive metric the FireBoard cloud API exposes — with live-adjustable polling and optional Drive control, all as entities (no YAML).
Pulls all data from the FireBoard cloud REST API (https://fireboard.io/api/v1) using your account credentials.
Requirements
- A FireBoard account (email + password) with at least one registered device.
- Home Assistant with outbound internet access to
fireboard.io. - For On Network detection only: the OS
pingbinary (standard on HAOS / Container).
Installation
Via HACS (recommended)
- Click the badge above (adds this repo to HACS), or in HACS → ⋮ → Custom repositories add
https://github.com/Ltek/fireboardas an Integration. - Install FireBoard, then restart Home Assistant.
Manual
- Copy
custom_components/fireboard/into your Home Assistantconfig/custom_components/folder. - Restart Home Assistant.
Set up
- Settings → Devices & Services → Add Integration → FireBoard, enter email + password.
- (Optional) On the second setup screen, enter each device’s LAN IP — or skip and add it later.
- Choose which optional entities to enable, then finish.
Options are changed anytime via Settings → Devices & Services → FireBoard → Configure, or directly from the entities below.
How it works
Polling. One devices.json call returns all devices with all nested data (every probe, battery, WiFi, onboard temp, model, firmware) — so a single poll refreshes almost everything and counts as one API request regardless of how many entities you have. FireBoard Drive data is the exception: it comes from a separate drivelog.json call per device. Cook sessions come from sessions.json (fetched on the same schedule, no extra per-entity cost). The API allows ~200 requests/hour; at the 40 s default that’s ~90/hour for devices, plus ~90/hour per Drive-enabled device.
Refresh rates are entities. The three interval Number entities and the polling Switches apply live (no restart) and persist across restarts, so you can tune them from the dashboard or automations. The 10 s minimum is for short-term probe-stability troubleshooting — sustained 10 s polling exceeds the rate limit, so return to 40 s+ afterward.
IP address (auto + manual). The cloud reports each device’s LAN IP (internalIP), which the integration caches automatically — so reconnection detection generally needs no manual entry. You can still type an IP in the LAN IP entity as an override/fallback; the cloud value is preferred while the device is online (it self-corrects after a new DHCP lease), and your manual value is used when it isn’t. Your typed value is never overwritten.
Reconnection detection (offline polling). Turn on a device’s Offline Polling switch and the integration pings its IP every ~20 s, adapting the API poll rate:
| Device state | API poll rate |
| Reporting to the cloud | Normal (Devices Refresh Interval) |
| On the network but cloud data still stale | Fast (Offline Refresh Interval) — catch the reconnection quickly |
| Confirmed off the network | Idle backoff (15 min) — conserve API calls |
The moment the IP reappears, an immediate refresh fires. (The fast “offline” rate only runs after the device is seen on-network, so a low value there doesn’t waste calls while it’s truly offline.)
Reliability. Bad/expired credentials trigger Home Assistant’s re-authentication prompt instead of silent failure. A transient rate-limit or network blip keeps the last known values (and recorder history) rather than flipping everything to unavailable — the blip shows on the Last Seen sensor’s update_state attribute.
Entities
Entities live on the physical FireBoard device, except the polling/connection controls which live on a “FireBoard Server Connection” service device. “Disabled by default” entities are created but must be enabled (per-entity, or in bulk via the Configure toggles).
Temperature & cook
| Entity | What it’s for | Default |
Channel N - <label> |
One temperature sensor per probe/port (label from the FireBoard app) | Enabled |
| Cook Session | Name of the active cook (unavailable when no cook running) | Enabled |
| Cook Started | Start time of the active cook | Enabled |
| Session Count | Number of cook sessions recorded for the device (diagnostic) | Disabled |
| Last Cook | Most-recent session name, with start/end/duration attributes | Disabled |
Device health
| Battery | Device battery % | Enabled |
| Battery Low | On when battery is low (< 20%) — diagnostic | Enabled |
| Connectivity | Online/offline from data freshness — diagnostic | Enabled |
| Last Seen | Timestamp of last report; carries poll-health attr — diagnostic | Enabled |
| Onboard Temperature | The FireBoard unit’s internal board temp (not a food probe) — diagnostic | Disabled |
| Battery Voltage | Actual battery volts (vBatt) — diagnostic |
Disabled |
| WiFi Signal | RSSI in dBm, with SSID/band/IP attributes — diagnostic | Disabled |
| WiFi Link Quality | Link quality % — diagnostic | Disabled |
Device info (all diagnostic, disabled by default)
IP Address, Public IP, MAC Address, WiFi Network (SSID), WiFi Band, WiFi Frequency, Uptime, Firmware Version, Channel Count, Model Name, Serial Number.
FireBoard Drive (fan controller)
Read entities require Drive Polling on (enabled by default) and a Drive attached.
| Drive Output | Current fan/blower output % | Enabled |
| Drive Setpoint | Current target temperature (read-only) | Enabled |
| Drive Lid Paused | On when the Drive is lid-paused | Enabled |
| Drive Battery | Drive battery voltage — diagnostic | Disabled |
Drive control
experimental (writes to hardware)
These write to the Drive via an endpoint FireBoard does not formally document. Drive Setpoint Target is enabled by default; the rest are disabled and enabled together via the Configure toggle.
| Drive Setpoint Target | Set the Drive’s target temperature (auto mode) | Enabled |
| Drive Fan Speed | Set a fixed fan % (manual mode) | Disabled |
| Drive Fan Running | Switch off = turn the Drive fan off | Disabled |
| Drive Control Channel | Which probe the Drive PID follows | Disabled |
Controls (on the “FireBoard Server Connection” device)
| Entity | Type | What it controls |
| Devices Refresh Interval | Number (10–300 s) | How often devices.json is polled |
| Drive Refresh Interval | Number (10–300 s) | How often drivelog.json is polled |
| Offline Refresh Interval | Number (10–300 s) | Fast rate to catch a reconnection |
| Drive Polling | Switch | Enable/disable Drive polling globally (default on) |
<device> LAN IP |
Text | Manual IP override for reconnection detection |
<device> Offline Polling |
Switch | Enable IP-based reconnection detection for that device |
<device> On Network |
Binary sensor | Live ping result (shows effective/cloud/manual IP) |
Configure toggles (Options flow)
- Enable diagnostic sensors — create the disabled-by-default diagnostic sensors enabled in bulk.
- Enable experimental Drive controls — create the disabled Drive control entities enabled in bulk.
Changing either reloads the integration; all other options apply live.
Notes & limitations
- Cloud-only: HA talks to FireBoard’s servers, not the device directly. “On Network” pinging is a reachability proxy — being on your LAN doesn’t guarantee the cloud has a fresh reading yet, so it triggers faster polling rather than fabricating values.
- Probes read unknown when idle: the API omits readings older than 60 s, so an unplugged/not-reporting probe correctly shows unavailable rather than a stale value.
- Drive control is experimental: the write endpoint is undocumented and controls physical hardware. Use realistic setpoints.
- Credentials are entered in the config flow, not exposed as entities.
