First Automation Help
I am trying to automate the turning on of lights depending on sun angle and time/day of week.
I have this started and cannot seem to find the correct combination to get this to function.
    sensors:
      solar_angle:
        friendly_name: "Sun angle"
        unit_of_measurement: 'degrees'
        value_template: "{{ state_attr('sun.sun', 'elevation') }}"
automation:
  - alias: 'Day Care Entry'
      platform: time
      at: '06:40:00'
      weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
    condition:
      condition: and
      conditions:
        - condition: numeric_state
          entity_id: 'sensor.solar_angle'
          below: 0
      - service: homeassistant.turn_on
        data_template:
          entity_id: >
              light.day_care_area_light
              light.day_care_single_light
              light.day_care_patio_light
Can someone please guide me to the correct code to get this to function?
Thanks,
      platform: time
      at: '06:40:00'
    condition:
      - condition: time
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
        entity_id: sensor.solar_angle
        below: 0
      entity_id:
        - light.day_care_area_light
        - light.day_care_single_light
        - light.day_care_patio_light
What Marc said will work. You also don’t need the template sensor if you replace the numeric state condition and use something like this instead:
- condition: template
  value_template: "{{ state_attr('sun.sun', 'elevation') < 0 }}"
Either works, just wanted to share.
and just to be safe and follow good practices you should force the state to an int (or float if you prefer) in the template. so…
  value_template: "{{ state_attr('sun.sun', 'elevation') | int  < 0 }}"
Ah thank you. Note that int will always round down even if the actual decimal is .5 or above.
