Here is what I did to auto-adjust color temperature for all the lights I want:
First, I have an automation that triggers every 10 minutes, whenever any lights change, or if the global color temperature changes. It triggers a “update_color_temperature” event.
- alias: Trigger Color Temperature Update
mode: single
- platform: time_pattern
minutes: "/10"
- platform: state
entity_id: sensor.on_lights
- platform: state
entity_id: input_select.global_color_temp_k
- delay: "00:00:05"
- event: update_color_temperature
Then I have a script that goes through all lights and looks for lights that are:
“on” AND “not groups” AND “in color_temp mode” AND “have a different color temp” AND "do not have no_ct in their name.
For all those bulbs, it sets the color temp to the value of input_select.global_color_temp_k.
This prevents any lights that are off from turning on, doesn’t change lights that are in color mode, and only updates lights that need to be updated. When a light is turned on, the update gets triggered and the light automatically adjusts.
For some lights that I don’t want to change, I just add “no_ct” to the end of their name and they are skipped.
- alias: Auto Update Lights Color Temperature
mode: restart
- platform: event
event_type: update_color_temperature
# - service: system_log.write
# data:
# message: >
# {% for state in states.light
# if is_state(state.entity_id, 'on')
# and (state_attr(state.entity_id, 'entity_id') == None)
# and (state_attr(state.entity_id, 'color_mode') == 'color_temp')
# and ('no_ct' not in state.entity_id) -%}
# {{state.entity_id}}{{ "," if not loop.last else "" }}
# {%- endfor %}
# level: warning
## 26-Aug-2022: Use a choose so we don't do anything if there are no lights to change
- choose:
# Check if there are any lights to adjust and only do so if there are!
- conditions: >
and (state_attr(state.entity_id,'color_temp')|int(370) != ((1000000/(states('input_select.global_color_temp_k')|int(2700)))|int))
{%- if loop.first -%}
{{"true" if loop.length>0 else "false"}}
{%- endif -%}
{%- endfor %}
sequence:
# data:
# message: "Need to adjust temperature."
# level: warning
- service: light.turn_on
entity_id: >
{%- endfor %}
color_temp: "{{(1000000/(states('input_select.global_color_temp_k')|int(2700)))|int}}"
transition: 10
However, I have some lights that don’t match in color temperature, so for them I have a custom calibration automation that is also triggered:
- alias: Update Color Temperature for Calibrated Lights
- platform: event
repeat:
for_each:
- light: light.living_room_white_led_strip_no_ct
calibration: [2700, 2128, 4000, 3015]
- light: light.living_room_tv_led_strip_no_ct
calibration: [2700, 2066, 4000, 4000]
- light: light.led_strip_2_no_ct
sequence:
# Check if it is on, not a group, and in color_temp mode
- if: "{{ is_state(repeat.item.light, 'on') and (state_attr(repeat.item.light, 'entity_id') == None) and (state_attr(repeat.item.light, 'color_mode') == 'color_temp') }}"
then:
# data:
# message: >
# {%- set desired_low = repeat.item.calibration[0]|int(2700) -%}
# {%- set actual_low = repeat.item.calibration[1]|int(2700) -%}
# {%- set desired_high = repeat.item.calibration[2]|int(4000) -%}
# {%- set actual_high = repeat.item.calibration[3]|int(4000) -%}
# {%- set scale = (actual_high-actual_low)/(desired_high-desired_low)|float(1.0) -%}
# {%- set offset = (actual_low)-(desired_low)*scale|float(0.0) -%}
# {%- set target = states('input_select.global_color_temp_k')|float(2700) -%}
# {%- set use = target*scale+offset -%}
# "Calibrated color temperature for {{repeat.item.light}} is {{use}} with scale: {{scale}}, offset: {{offset}}, target: {{target}}."
entity_id: "{{ repeat.item.light }}"
kelvin: >
{{ target*scale+offset|int(target) }}
transition: 10
I also have automations that change the color temperature during the day. This also triggers an update of all bulbs:
- alias: "Auto Color Temp Wakeup 1"
platform: time
at: "06:00:00"
- service: input_select.select_option
option: "2700"
- alias: Auto Color Temp Morning 2
platform: time
at: "06:55:00"
option: "3000"
- alias: Auto Color Temp Day 3
platform: time
at: "08:00:00"
option: "3300"
- alias: Auto Color Temp Afternoon 4
platform: time
at: "17:00:00"
option: "3000"
- alias: Auto Color Temp Evening 5
platform: time
at: "20:00:00"
option: "2700"
- alias: Auto Color Temp Night 6
platform: time
at: "22:00:00"
option: "2500"
The problem of turning off lights and losing them from the mesh is a big one!
I have 14 bulbs on track lights, and when the wall switch goes off the mesh gets totally screwed up.
So what I did was have one ZigBee network for those bulbs and one for remotes. This means even when the wall switch is shut off, the network the remotes are on does not get affected.
