First automation: Whats wrong?
I checked many examples and the docs and built this:
automations.yaml
- alias: Fenster auf Wohnzimmer
    platform: state
    entity_id: binary_sensor.oeq1986163_state
    to: 'on'
    - service: input_number.set_value
      data_template:
        entity_id: input_number.old_temp_wohnzimmer
        value: '{{ states.climate.wohnzimmer.attributes.temperature | float }}'
    - service: climate.set_temperature
        entity_id: climate.wohnzimmer
        temperature: '4.5'
- alias: Fenster zu Wohnzimmer
    platform: state
    to: 'off'
    data_template:
      temperature: '{{ states.input_number.old_temp_wohnzimmer.state }}'
and the check says:
> Invalid config for [automation]: invalid template (TemplateSyntaxError: Encountered unknown tag ‘input_number’.) for dictionary value @ data[‘action’][0][‘data_template’][‘temperature’]. Got None. (See /config/configuration.yaml, line 14). Please check the docs at https://home-assistant.io/components/automation/
edit: It’s working now!
configuration.yaml:
input_number:
  old_temp_wohnzimmer:
    name: Wohnzimmer Temperatur vor Aktion
    min: 4.5
    max: 35
    step: 0.5
    mode: box
What am I doing wrong again?
     temperature: "{{ states('input_number.old_temp_wohnzimmer') }}"
or
That was a hit. Still not behaving right, mixed ‘on’ and ‘off’ up I think, will check that later :slight_smile:
Thank you!
See https://www.home-assistant.io/integrations/binary_sensor/#device-class
Typically for a window, ‘on’ means open and ‘off’ means closed.
Cool, thank you.
Got it working, editing the correct code to the initial posting.
