I’m building a “Pool Controller” on an ESP DEV kit as a 1st time real world ESP project. The device will include:
- Tamper switch if the pool equipment panel door is opened
- Local motion sensor
- Pressure sensor (5v 0-30PSI connected to an ADC input) to monitor filter pressure
- 4 on/off switches to control 4 relays (12v landscape lighting)
Future additions:
- local weather-proof ambient temperature sensor(s)
- piggy back the existing OmiPool flow sensor
- local weather-proof button camera (motion triggered)
I’m super interested in how my code could be better, more efficient, more compact, etc. I realize I’m not optimizing the logger yet, and haven’t tried OTA yet. Internal ESP temp sensor was for fun and learning more than anything. I’d rather modularize things a bit and replace GPIO names with zone names. I’m working my way to getting this all to work with Konnected.io ESP YAMLS
It’s all working on the desktop, hasn’t crashed running over 24hours.
The environment is SmartThings, HomeAssistant, Konnected, ActionTiles, Hayward Omnipool (not that it matters), wifi or wired available.
substitutions:
device_name: <REDACTED>
esphome:
friendly_name: Soupasaurus
esp32:
board: esp32doit-devkit-v1
framework:
type: arduino
# Enable Home Assistant API
api:
encryption:
key: "<REDACTED>"
# WiFi section, build connection
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "<REDACTED>"
password: "<REDACTED>"
# additional components
captive_portal:
web_server:
include_internal: true
logger:
ota:
text_sensor:
# Formatted UPTIME output DD:HH:MM:SS (for fun)
update_interval: 60s
lambda: |-
auto s = millis() / 1000;
return str_snprintf("%02d:%02d:%02d:%02d", 11, s / 86400, s / 3600 % 24, s / 60 % 60, s % 60);
icon: mdi:clock-start
- platform: wifi_info
ip_address:
icon: mdi:ip
ssid:
icon: mdi:wifi
mac_address:
icon: mdi:ip
# BINARY SENSORS
binary_sensor:
- platform: gpio
device_class: tamper
icon: mdi:alert-box-outline
pin:
number: GPIO4
mode: INPUT_PULLUP
inverted: True
- platform: gpio
device_class: motion
pin:
number: GPIO2
mode: INPUT_PULLUP
inverted: True
icon: mdi:motion-sensor
# REGULAR SENSORS
- platform: uptime
- platform: internal_temperature
name: Internal temperature C
unit_of_measurement: C
icon: mdi:temperature-celcius
name: Internal temperature F
lambda: return id(int_temp_c).state * 9/5 + 32;
unit_of_measurement: F
icon: mdi:temperature-fahrenheit
- platform: adc
name: "Filter Pressure (raw)"
pin: GPIO35
update_interval: 10s
# https://github.com/esphome/esphome/discussions/2990
# Pressure sensor: 0 to 30 psi (more accurately, 0 to 2 bar) with an alleged 0.5-4.5V range
# 0.5V = 0 psi / 0.00 bar / 0 kPa
# 2.5V = 15 psi / 2.00 bar / 200 kPa
# 4.5V = 30 psi / 4.00 bar / 400 kPa
# For the ESP, voltage is scaled by a 3.3k/1k voltage divider, so.... for a 30psi sensor
# Min scale = 0.116V
# Max scale = 1.047V
# 0.116V = 0 psi / 0.00 bar / 0 kPa
# 0.466V = 15 psi / 1.00 bar / 100 kPa
# 1.047V = 30 psi / 2.00 bar / 200 kPa
- platform: copy
source_id: filter_pressure_sensor_volts
name: Filter Pressure (PSI)
unit_of_measurement: 'psi'
filters:
- calibrate_linear:
- 0.116 -> 0.0
- 0.581 -> 15.0
- 1.047 -> 30.0
icon: mdi:gauge
- platform: wifi_signal
name: WiFi Signal RSSI
accuracy_decimals: 1
- platform: copy
source_id: wifi_signal_db
name: WiFi Signal %
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
switch:
# Used to control light relays
- platform: gpio
pin: GPIO18
icon: mdi:power
- platform: gpio
pin: GPIO14
icon: mdi:power
- platform: gpio
pin: GPIO33
icon: mdi:power
- platform: gpio
pin: GPIO32
icon: mdi:power
type or paste code here
