Hi there.
This entire thing is someone else’s brain child, although I set this up so long ago, I can’t recall who I need to give credit to ![]()
The really relevant parts are as follows:
esp8266:
board: d1_mini
esphome:
includes:
- custom_sensor.h
external_components:
- source:
type: git
url: https://github.com/robertklep/esphome-custom-component
components: [ custom, custom_component ]
logger:
level: INFO
# The rest of your code for the node
# Mains Voltage Sensor
- platform: custom
lambda: |-
auto my_sensor = new ZMPT101BSensor();
App.register_component(my_sensor);
return {my_sensor};
sensors:
unit_of_measurement: V
state_class: "measurement"
accuracy_decimals: 2
icon: "mdi:current-ac"
filters:
- lambda: |
if (x < 120) return 0;
else return (x);
- sliding_window_moving_average:
window_size: 5
send_every: 5
on_value:
then:
- if:
- lambda: 'return id(${sen_id}).state > 240;'
then:
- switch.turn_on: ${sen_id}_high
else:
- switch.turn_off: ${sen_id}_high
- if:
and:
- lambda: 'return id(${sen_id}).state <= 240;'
- lambda: 'return id(${sen_id}).state > 210;'
then:
- switch.turn_on: ${sen_id}_ok
else:
- switch.turn_off: ${sen_id}_ok
- if:
and:
- lambda: 'return id(${sen_id}).state <= 210;'
- lambda: 'return id(${sen_id}).state > 180;'
then:
- switch.turn_on: ${sen_id}_low
else:
- switch.turn_off: ${sen_id}_low
- if:
- lambda: 'return id(${sen_id}).state <= 180;'
then:
- switch.turn_on: ${sen_id}_no_power
- light.turn_on:
brightness: 50%
effect: pulse
else:
- switch.turn_off: ${sen_id}_no_power
- light.turn_off: led_${sen_id}_status
binary_sensor:
lambda: |-
return id(${sen_id}).state > 140.0;
I didn’t know if you’d want to use the “High”, “Ok”, “Low” etc, so I just left that in, and I also added the binary sensor for the sake of having a definitive On/Off state.
And a manually created file named custom_sensor.h, which needs to go in the root of your ESPHome directory with the contents being:
#include "esphome.h"
#include <Arduino.h>
#define VMAX 250
#define FREQUENCY 50
#define CALIBRATE_READ 130
#define CALIBRATE_ACTUAL 225.25
#define ZERO_VAC 796
class ZMPT101BSensor : public PollingComponent, public Sensor {
public:
// constructor
ZMPT101BSensor() : PollingComponent(1000) {}
float get_setup_priority() const override { return esphome::setup_priority::HARDWARE; }
void setup() override {
// This will be called by App.setup()
void update() override {
// This will be called every "update_interval" milliseconds.
uint32_t period = 1000000 / FREQUENCY;
uint32_t t_start = micros();
uint32_t Vsum = 0, measurements_count = 0;
int32_t Vnow;
while (micros() - t_start < period) {
Vnow = analogRead(A0) - ZERO_VAC;
Vsum += Vnow*Vnow;
measurements_count++;
float Vrms = sqrt(Vsum / measurements_count) / CALIBRATE_READ * CALIBRATE_ACTUAL;
publish_state(int(Vrms));
For setting up the ZMPT101B you can just watch these 3 videos:
to get a better understanding of the calibration, otherwise, if you do a search for ZMPT101B Calibration, there are a couple of YouTube videos that show you how to calibrate this sensor with Arduino code, which is the way I did it, and then just re-flashed the node in ESPHome afterwards.
As all the videos recommend, Be Very mindful of the fact that you are messing with Mains Voltage! (Thought I’d better include that
There will be some final adjustments you would need to make to the custom_sensor.h in the end, as the measurements at your DB and mine would be considerably different depending if you are being supplied 110v, 220v, 250v etc in this section:
#define VMAX 250
This article also gives a fair amount of setup and advice:
Hope this helps!
