First steps with Home Assistant: No connection to Ikea Tradfri
Hi!
Actually I run my first home automation. I decided to use Home Assistant.
But i have one problem: At the moment i only have some Ikea Tradfri lights that run on ZigBee protocol, as far as i know.
I bought a CC2531 USB stick to control them.
The CC2531 is recognized by HomeAssistant.
I have installed Mosquitto Broker and ZigBee2MQTT. The setup of Mosquitto Broker and ZigBee2MQTT seems correct, i have created a user and it is written in the config file of ZigBee2MQTT.
No errors so far in the logfile.
But i cant recognize any of my Tradfri LED lights.
Any advice/ideas?
Thanks a lot!
You paired the lights already to the coordinator (stick) ?
Thanks a lot!
You pointed me in the right direction.
I did not see the small button on the USB Stick. Works! :slight_smile:
Good you found the problem.
