First time install of Home Assistant Green stuck in Preparing Home Assistant
I just connected my new Home Assistant Green for the first time but it is stuck in the preparing stage.
Looking at the logs it is failing on downloading the landingpage. I see this repeatedly in the logs:
2026-04-09 22:29:57.024 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-04-09 22:30:12.030 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-04-09 22:30:19.005 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2026.4.1
2026-04-09 22:30:19.717 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2026.4.1.
2026-04-09 22:30:21.217 ERROR (MainThread) [supervisor.docker.manager] failed commit on ref "layer-sha256:a126363a87c1871f6f20c4d57db4efe4d7f72e889fbb44c168119c034c496720": commit failed: unexpected commit digest sha256:3178bcdeedf5f3e8cea395d69e0471b31b6cbe3400e3d29b38d04ac00e108b84, expected sha256:a126363a87c1871f6f20c4d57db4efe4d7f72e889fbb44c168119c034c496720: failed precondition
2026-04-09 22:30:21.219 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
It seems to succeed downloading the first few packages:
2026-04-09 21:22:59.790 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-dns:2025.08.0 to ghcr.io/home-assistant/aarch64-hassio-dns:2026.02.0
2026-04-09 21:23:12.665 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-audio:2025.08.0 to ghcr.io/home-assistant/aarch64-hassio-audio:2026.02.0
2026-04-09 21:23:22.264 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-observer:2025.02.0 to ghcr.io/home-assistant/aarch64-hassio-observer:2026.02.0
2026-04-09 21:23:26.632 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-multicast:2025.08.0 to ghcr.io/home-assistant/aarch64-hassio-multicast:2026.02.0
So I think the internet set up is OK.
I did try a factory reset and still get the same results.
Any ideas?
NVM resolved it. I have to do clean shut down before factory reset.
  1. Press power button 6 seconds
  2. Let go
  3. wait till LEDs goes off
Then the factory reset startup works.
Make sure you are waiting long enough. It takes linger that you think and longer that they state…
This is an embarrassing glitch.
When u insert a drive with install medium. It should start on that when reboot.
Now youre lucky ifnit manage to start and install.
So fixing a bad install, i.e. if u removed all Addons from interface or something, is a hard days work.
I managed one reinstall but injected a backup with my same error, and when I try to reinstall again to have a clean new homeassistant, it fails .
You say wait long enough. 5 hours is enough?
2 x 4hours?
I need Nabu to fix this asap. I need my HA green back for my lights.
