You could give this a try.
[{"id":"d8f3b856.078788","type":"timecheck","z":"d6a46901.ebee1","name":"","time":"22:00","x":790,"y":1000,"wires":[["926b0319.1643e"],["c6c43ae3.98d33"]]},{"id":"926b0319.1643e","type":"traffic","z":"d6a46901.ebee1","name":"hold till morning","property_allow":"payload","filter_allow":"release","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"hold","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":true,"differ":true,"x":1160,"y":980,"wires":[["c6c43ae3.98d33"]]},{"id":"410fd4d.15414ac","type":"server-state-changed","z":"d6a46901.ebee1","name":"washing machine done ","server":"","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":140,"y":1020,"wires":[["8e803406.506fb8"]]},{"id":"8e803406.506fb8","type":"api-current-state","z":"d6a46901.ebee1","name":"Home/Away","server":"","version":1,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"person.group","state_type":"str","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":450,"y":1020,"wires":[["d8f3b856.078788"],["fe8f043a.6a1008","6b06baba.3c22bc"]],"outputLabels":["Home","Away"],"icon":"font-awesome/fa-question"},{"id":"7afef1a6.8e5be","type":"traffic","z":"d6a46901.ebee1","name":"hold till someone is home","property_allow":"payload","filter_allow":"release","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"hold","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":true,"differ":true,"x":1150,"y":1140,"wires":[["c6c43ae3.98d33"]]},{"id":"e53882fa.d0ec2","type":"inject","z":"d6a46901.ebee1","name":"hold starts at","props":[{"p":"payload"}],"repeat":"","crontab":"00 22 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"hold","payloadType":"str","x":680,"y":860,"wires":[["926b0319.1643e"]]},{"id":"f923d960.c35c7","type":"inject","z":"d6a46901.ebee1","name":"hold releases at","props":[{"p":"payload"}],"repeat":"","crontab":"00 08 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"release","payloadType":"str","x":710,"y":920,"wires":[["926b0319.1643e"]]},{"id":"fe8f043a.6a1008","type":"change","z":"d6a46901.ebee1","name":"hold message","rules":[{"t":"set","p":"payload","pt":"msg","to":"hold","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":1120,"wires":[["7afef1a6.8e5be"]]},{"id":"6b06baba.3c22bc","type":"delay","z":"d6a46901.ebee1","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":740,"y":1060,"wires":[["7afef1a6.8e5be"]]},{"id":"c6c43ae3.98d33","type":"api-call-service","z":"d6a46901.ebee1","name":"tts","server":"","version":1,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1480,"y":1080,"wires":[[]]},{"id":"d1da99f2.ba10e8","type":"server-state-changed","z":"d6a46901.ebee1","name":"person.group away to home","server":"","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":160,"y":1180,"wires":[["a8b81733.713698"]]},{"id":"a8b81733.713698","type":"ha-wait-until","z":"d6a46901.ebee1","name":"front door opens","server":"","outputs":1,"entityId":"","entityIdFilterType":"exact","property":"","comparator":"is","value":"","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":430,"y":1180,"wires":[["62b02415.4703dc"]]},{"id":"62b02415.4703dc","type":"change","z":"d6a46901.ebee1","name":"release message ","rules":[{"t":"set","p":"payload","pt":"msg","to":"release","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":1180,"wires":[["7afef1a6.8e5be"]]}]
Actually the time check is not needed and wouldn’t work for this scenario anyway.
[{"id":"926b0319.1643e","type":"traffic","z":"d6a46901.ebee1","name":"hold till morning","property_allow":"payload","filter_allow":"release","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"hold","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":true,"differ":true,"x":1020,"y":1000,"wires":[["c6c43ae3.98d33"]]},{"id":"410fd4d.15414ac","type":"server-state-changed","z":"d6a46901.ebee1","name":"washing machine done ","server":"","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":140,"y":1020,"wires":[["8e803406.506fb8"]]},{"id":"8e803406.506fb8","type":"api-current-state","z":"d6a46901.ebee1","name":"Home/Away","server":"","version":1,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"person.group","state_type":"str","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":450,"y":1020,"wires":[["926b0319.1643e"],["fe8f043a.6a1008","6b06baba.3c22bc"]],"outputLabels":["Home","Away"],"icon":"font-awesome/fa-question"},{"id":"7afef1a6.8e5be","type":"traffic","z":"d6a46901.ebee1","name":"hold till someone is home","property_allow":"payload","filter_allow":"release","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"hold","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":true,"differ":true,"x":1030,"y":1140,"wires":[["c6c43ae3.98d33"]]},{"id":"e53882fa.d0ec2","type":"inject","z":"d6a46901.ebee1","name":"hold starts at","props":[{"p":"payload"}],"repeat":"","crontab":"00 22 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"hold","payloadType":"str","x":680,"y":860,"wires":[["926b0319.1643e"]]},{"id":"f923d960.c35c7","type":"inject","z":"d6a46901.ebee1","name":"hold releases at","props":[{"p":"payload"}],"repeat":"","crontab":"00 08 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"release","payloadType":"str","x":710,"y":920,"wires":[["926b0319.1643e"]]},{"id":"fe8f043a.6a1008","type":"change","z":"d6a46901.ebee1","name":"hold message","rules":[{"t":"set","p":"payload","pt":"msg","to":"hold","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":1120,"wires":[["7afef1a6.8e5be"]]},{"id":"6b06baba.3c22bc","type":"delay","z":"d6a46901.ebee1","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":740,"y":1060,"wires":[["7afef1a6.8e5be"]]},{"id":"c6c43ae3.98d33","type":"api-call-service","z":"d6a46901.ebee1","name":"tts","server":"","version":1,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1350,"y":1060,"wires":[[]]},{"id":"d1da99f2.ba10e8","type":"server-state-changed","z":"d6a46901.ebee1","name":"person.group away to home","server":"","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":160,"y":1180,"wires":[["a8b81733.713698"]]},{"id":"a8b81733.713698","type":"ha-wait-until","z":"d6a46901.ebee1","name":"front door opens","server":"","outputs":1,"entityId":"","entityIdFilterType":"exact","property":"","comparator":"is","value":"","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":430,"y":1180,"wires":[["62b02415.4703dc"]]},{"id":"62b02415.4703dc","type":"change","z":"d6a46901.ebee1","name":"release message ","rules":[{"t":"set","p":"payload","pt":"msg","to":"release","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":1180,"wires":[["7afef1a6.8e5be"]]}]
