First try of operation panel, 2 decimal problem
Hi there!
I´m using a product called “husdata” that sends mqtt from my heatingpump.
I got the values for my picture:
But the problem I have is that the values are in 2 decimals. I can´t find how to change this to 1?
This is my mqtt setup for one sensor in configuration.yaml:
  - platform: mqtt
    state_topic: "b4e62d65a999/HP/0007"
    unit_of_measurement: "°C"
    icon: mdi:thermometer
edit: This is my picture-element for that sensor
  - type: state-label
    entity: sensor.outdoor
    style:
      top: 10%
      left: 8%
Try with a value template. You can also use device_class: temperature see here for more details, then you don’t need to set unit of measurement and icon.
- platform: mqtt
  value_template: "{{ value_json | round(1) }}"
I also wonder if there’s a way to get the picture bigger?
Did the code work?
Please open a separate topic for this.
The decimal work but not the unit
So add unit of measurement back and your good to go.
Thank you!
