Fitbit Integration Setup Fails
I’m trying to set up the Fitbit configuration and it is failing. I followed the instruction exactly. When I fill out the client ID and secret it opens up the fitbit site, but shows this error:
I’m sure I’m doing something wrong, but can’t figure it out.
I figured out the redirect URL needs to match the HA url you are using to add the integration. I was able to select the sensors I want, but HA threw an error. This is all that is in the log:
2025-05-01 09:51:52.093 ERROR (MainThread) [homeassistant.components.fitbit.config_flow] Failed to fetch user profile for Fitbit API: Error from fitbit API
Problem was I only selected some of the sensors. Selecting all works
