Hi
The fitbit integration doesn’t provide data about exercise activities.
So I was hoping to use the fitbit webhook.
The problem is, fitbit wants the webhook to be verified before it will send data
" 1. Verify your subscriber endpoint as described in Verify a Subscriber. This will require adding code to respond correctly to a verification code."
Anyone found a way around this? I can’t seem to get a webhook to return data
