I noticed that two of my devices energy is negative in 2 places. When i look at the sensor value (in W), they is flat line/ zero for brief period of time. Could this be the reason? If so how can avoid/fix this?
Can you also send the graph for the energy sensors and go to the actual month and day and look at which hour it happend?
Generally you can fix history data under developer settings, statistics and the grpah icon of the sensor.
zoomed plot
sensor1
sensor2
As you can see that i don’t have the graph icon for these two sensors, could there be a problem with some settings?
sensor1
sensor2
edit:
i was looking at power sensors in statistics. i found the energy sensors. there is no value stored on those dates.
for sensor1
when i clicked outliers, it shows some negative values, i changed them to zero. is it the right way to do?
Before the edit: You sent the power sensors again. Look for the same entities you set in the energy dashboard config.
After: Yes this is the way. The no data points are caused by the time. Look at the hourly resolution of the wrong day and set the time correspondingly.
