My Home Assistant system is fully up-to-date (Core: 2024.12.5, Supervisor: 2024.12.0, Operating System: 14.1, Frontend: 20241127.8). It is a fairly vanilla system, but I do have ESP Home installed. However, for the past several months, whenever I click on ‘ESP Home’ in the sidebar, the message ‘Supervisor: Unable to fetch add-on info to start Ingress’ appears and then the list of add-ons is shown. Clearly something is wrong – how do I fix this?
Are you using the correct ESPHome addon repository?
There was a change to a new repository ages ago.
tom_l: Thanks for the reply, but… How do I check to see if that the correct ESPhome add-on repository is being used?
I did a tad of looking around and figured that I could try adding the official repository, GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on, to HA. I went to HA-> ESPhome, clicked the three dots in the upper right hand corner, and selected Repositories. I tried adding the above URL, but was told I cannot.
Have you checked the supervisor logs?
Try to reinstall the add-on maybe.
Thanks for replying. Per your suggestion, I looked at the supervisor log and see a bunch of issues. When I searched, I see a bunch of people talking about the systems frequently restarting itself, so I just added the Uptime service.
Sadly, I have not yet seen anything suggesting how to fix the issue, though it does not seem to be uncommon. Any chance I could email you my log file and you could offer a thought? If so, please share your email address. Thanks.
