Flaky ZooZ Relay
Maybe this has been answered, but I couldn’t find it in my search. I have a ZooZ Zen52 relay that is giving me problems. It shows as dead most of the time, but appears to wake up when the physical switches are toggled. Even then, you can’t do anything with it in HA.
I would like to remove it and try to re-add. It won’t go into exclusion mode at all. When I force remove it, I get an error that the node is not in the list of failed nodes. Is there any way to manually mark it as a failed node? I am using NodeJS. Any other ideas to remove the device from HA?
