Flamingo fa21rf (security1) tripping alarm in home assistant
Dear all,
I am migrating from Domoticz and I am quite impressed with the ease setting up the system in HA. However, one thing I cannot find on how to setup and I doubt that I am the first one with this problem. Still I cannot find the answer and therefore, post my question here.
In Domoticz I used my six Flamingo fa21rf smoke detectors also as a siren. As these are all coupled, sending the code through the rfxcom, I could let them all off. In HA however, I can only manage to have them as a sensor.
At the moment I have the sensor added in this way:
binary_sensor:
- platform: rfxtrx
  automatic_add: false
  devices:
    "08200300ef1b000660":
      device_class: smoke
      off_delay:
        seconds: 60
      fire_event: true
I also tried to put this block inside the switch definitions, however this did not work. Does anyone here have an idea to have these smoke detectors trip from HA?
I have the same 6 connected detectors and I want to do the same. But i want also a message, when they detect smoke.
With the switch option, I am not getting the signal, when the detectors are detecting smoke.
For this I am still looking for an solution.
My current situation:
I have used the switch option to trigger the smoke detector sirene from-out home assistant.
This is the code I used:
Switches RFlink
switch:
  • platform: rflink
    devices:
    fa20rf_3d1e1d_01:
Einde Switches RFlink
How do you manage to get your device ID with the Flamingo FA21RF ?
I’ve tried :
binary_sensor:
  platform: rfxtrx
  automatic_add: true
But no new binary sensor appeared in HA state.
I have used a RFLink from:
https://www.nodo-shop.nl/nl/rflink-gateway/195-rflink-43342-somfy-rts-arduino-antenne-usb-kabel.html
It could send a message to the smoke detectors. But no battery, it was not that good for me.
I changed them for the heimann smoke detectors with Zigbee. They are working fine. It has a battery sensor and a binary sensor for the smoke. You can not trigger them to sound a alarm.
