I have been able to flash this device using the serial cable. It all looks fine, the device appears online, etc.
When I try to update the device over the air (OTA) (wirelessly in ESPhome terms), I get the error message: “ERROR Error auth result: Error: Authentication invalid. Is the password correct?”
I need help. Did anyone come across this issue before?
And when I try to add the device to Home Assistant, I get the following message: “Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.”. The thing is I have an ‘api:’ line…
Did you originally flash this a while ago? Something similar is happening to me on devices I created a year+ ago. They had an API password, and apparently now there is a requirement to use an API key instead of a password. Not sure if it’s related to either of our issues though.
Answer to myself: I have been able to resolve the issue. The problem is that I was using the wrong power sensor. Mine is a Dual R3 V2 and it uses the BL0939 power sensor. When I applied the configuration for the correct power sensor, everything worked!
The error message ESPhome was giving is misleading. I spent a lot of time trying to figure out why the authentication error was happening and in the end it had nothing to do with authentication.
