Flex Table and Aggregating Data
Hi Everyone,
I’m playing around with customizing the display of the Dark Sky sensors. I’m trying to aggregate multiple sensors into an hourly table. Instead of doing it by hand it seems as though using Flex Table might be a good approach since it loops over sensors, however I’m running into a bit of an issue. Below is a snipped from my ui-lovelace.yaml file
  - title: Weather
    cards:
      - type: custom:flex-table-card
        entities:
          include: sensor.dark_sky_wind*
        columns:
          - name: Wind Speed (mph)
            prop: >
              {% if name.startswith("Dark Sky Wind Speed") %}
              state
              {% endif %}
          - name: Wind Bearing
            prop: state
I’ve been playing around with a couple of ways to get it so I can have a single row show the states of several sensors for each hour. Here I am just trying to get Wind Speed and Wind Bearing to show in a single row. Has anyone attempted to accomplish something like this? I keep hitting road blocks with trying to having multiple sensors show their data in a single row. Any pointers to get me in the right direction are greatly appreciated.
So I’ve changed the path I’m going down to achieve this and could use some input as to what I may be doing wrong. This mostly works as expected, however when I manually trigger the automation the output in lovelace is literally the text i use to try to set the attribute values to. I’m thinking i’m pretty close, but just missing something relatively minor to wrap it up.
Configuration.yaml for variable definition
 variable:
   dark_sky_hourly:
     value: 'Unknown'
     attributes:
       wind_bearing:
       wind_speed:
Automation.yaml to keep track of the state changes to sensor.dark_sky_wind_speed_?h.state
- id: update-variable-dark-sky
  alias: update_variable_dark_sky
    platform: state
    entity_id: sensor.dark_sky_wind_speed_0h
    - service: variable.set_variable
        variable: dark_sky_hourly
        value: 0
        attributes:
          wind_speed:
            - "{{ sensor.dark_sky_wind_speed_0h.state }}"
            - sensor.dark_sky_wind_speed_1h.state
ui-lovelace.yaml put data in flex card
  - title: Weather
    cards:
        entities:
          include: variable.dark_sky_hourly
        columns:
            attr_as_list: wind_speed
          - name: Value
            prop: state
The result ends up looking like this
Capture
I was able to resolve this rather simply by changing the automation.yaml action from data: to data_template: I’ve also added the following
  • an additional automation to trigger populating the variable on start
  • now updates in 30 minute increments
  • change layout to panel so all the table goodness can show without squishing
  • was able to aggregate the weather icon and weather summary onto a single line
New and Working code sections looks like this:
Configuration.yaml
variable:
  dark_sky_hourly:
    value: 0
    attributes:
      wind_bearing:
      wind_speed:
Automation.yaml
- id: startup-variable-dark-sky
  alias: startup_variable_dark_sky
    platform: homeassistant
    event: start
    - service: automation.trigger
      entity_id: automation.update_variable_dark_sky
    platform: template
    value_template: >
      {{ (as_timestamp(now()) - states.variable.dark_sky_hourly.state) > 30 }}
      data_template:
        value: "{{ as_timestamp(now()) }}"
        attributes:
          apparent_temperature:
            - "{{ states.sensor.dark_sky_apparent_temperature_0h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_1h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_2h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_3h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_4h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_5h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_6h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_7h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_8h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_9h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_10h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_11h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_12h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_13h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_14h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_15h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_16h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_17h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_18h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_19h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_20h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_21h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_22h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_23h.state }}"
            - "{{ states.sensor.dark_sky_apparent_temperature_24h.state }}"
          cloud_coverage:
            - "{{ states.sensor.dark_sky_cloud_coverage_0h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_1h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_2h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_3h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_4h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_5h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_6h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_7h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_8h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_9h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_10h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_11h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_12h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_13h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_14h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_15h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_16h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_17h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_18h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_19h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_20h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_21h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_22h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_23h.state }}"
            - "{{ states.sensor.dark_sky_cloud_coverage_24h.state }}"
          precip_probability:
            - "{{ states.sensor.dark_sky_precip_probability_0h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_1h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_2h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_3h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_4h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_5h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_6h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_7h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_8h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_9h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_10h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_11h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_12h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_13h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_14h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_15h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_16h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_17h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_18h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_19h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_20h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_21h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_22h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_23h.state }}"
            - "{{ states.sensor.dark_sky_precip_probability_24h.state }}"
          summary:
            - "<img src=\"{{ states.sensor.dark_sky_summary_0h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_0h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_1h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_1h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_2h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_2h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_3h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_3h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_4h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_4h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_5h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_5h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_6h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_6h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_7h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_7h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_8h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_8h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_9h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_9h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_10h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_10h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_11h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_11h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_12h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_12h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_13h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_13h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_14h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_14h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_15h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_15h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_16h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_16h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_17h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_17h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_18h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_18h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_19h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_19h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_20h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_20h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_21h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_21h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_22h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_22h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_23h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_23h.state }}"
            - "<img src=\"{{ states.sensor.dark_sky_summary_24h.attributes.entity_picture }}\" /> {{ states.sensor.dark_sky_summary_24h.state }}"
          temperature:
            - "{{ states.sensor.dark_sky_temperature_0h.state }}"
            - "{{ states.sensor.dark_sky_temperature_1h.state }}"
            - "{{ states.sensor.dark_sky_temperature_2h.state }}"
            - "{{ states.sensor.dark_sky_temperature_3h.state }}"
            - "{{ states.sensor.dark_sky_temperature_4h.state }}"
            - "{{ states.sensor.dark_sky_temperature_5h.state }}"
            - "{{ states.sensor.dark_sky_temperature_6h.state }}"
            - "{{ states.sensor.dark_sky_temperature_7h.state }}"
            - "{{ states.sensor.dark_sky_temperature_8h.state }}"
            - "{{ states.sensor.dark_sky_temperature_9h.state }}"
            - "{{ states.sensor.dark_sky_temperature_10h.state }}"
            - "{{ states.sensor.dark_sky_temperature_11h.state }}"
            - "{{ states.sensor.dark_sky_temperature_12h.state }}"
            - "{{ states.sensor.dark_sky_temperature_13h.state }}"
            - "{{ states.sensor.dark_sky_temperature_14h.state }}"
            - "{{ states.sensor.dark_sky_temperature_15h.state }}"
            - "{{ states.sensor.dark_sky_temperature_16h.state }}"
            - "{{ states.sensor.dark_sky_temperature_17h.state }}"
            - "{{ states.sensor.dark_sky_temperature_18h.state }}"
            - "{{ states.sensor.dark_sky_temperature_19h.state }}"
            - "{{ states.sensor.dark_sky_temperature_20h.state }}"
            - "{{ states.sensor.dark_sky_temperature_21h.state }}"
            - "{{ states.sensor.dark_sky_temperature_22h.state }}"
            - "{{ states.sensor.dark_sky_temperature_23h.state }}"
            - "{{ states.sensor.dark_sky_temperature_24h.state }}"
          wind_bearing:
            - "{{ states.sensor.dark_sky_wind_bearing_0h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_1h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_2h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_3h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_4h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_5h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_6h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_7h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_8h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_9h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_10h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_11h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_12h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_13h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_14h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_15h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_16h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_17h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_18h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_19h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_20h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_21h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_22h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_23h.state }}"
            - "{{ states.sensor.dark_sky_wind_bearing_24h.state }}"
          wind_speed:
            - "{{ states.sensor.dark_sky_wind_speed_0h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_1h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_2h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_3h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_4h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_5h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_6h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_7h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_8h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_9h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_10h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_11h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_12h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_13h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_14h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_15h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_16h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_17h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_18h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_19h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_20h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_21h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_22h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_23h.state }}"
            - "{{ states.sensor.dark_sky_wind_speed_24h.state }}"
ui-lovelace.yaml
  - title: Weather
    cards:
      - type: vertical-stack
        cards:
          - type: weather-forecast
            entity: weather.dark_sky
            entities:
            columns:
              - name: Summary
                attr_as_list: summary
              - name: Temp
                attr_as_list: temperature
              - name: Feels Like
                attr_as_list: apparent_temperature
              - name: Cloud Coverage
                attr_as_list: cloud_coverage
              - name: Precip
                attr_as_list: precip_probability
                attr_as_list: wind_bearing
    panel: true
    path: Weather
Here is what the end result looks like so far.
Here is what I have on my wish list for this part of the project:
  • Change up file structure to use directories to better organize code
  • Upload code to GitHub for change control and sharing
  • Revisit the giant lists of attributes and wrap them in loops, if possible, to make it a bit more dynamic with potentially ending up in a custom card
Any chance you continued your work with this? I’m looking for a solution to the borky iOS issue.
I’ve done some tweaks and updates to it since. Not sure why I missed your reply. You need some help?
Hope this isn’t too off topic? Didn’t think it warranted its own topic!
My VoIP software (FreePBX) is able to forward the caller ID of incoming callers to Hass. It’s pretty neat and I’m a big fan! Is there a way to change the way the log of callers is displayed? At the moment it’s just a glance entity on my lovelace and I have to click the sensor to browse the graph to see when the number changed. It’s not the best way to display this data. The best way would be a table. Is it possible to use flex-table-card to display this data in a list? I guess first I’d maybe have to change how the numbers are held in memory? Or not? I guess the info is there now.
If you get that data into sensors then you should be able to take the majority of what I did and make the necessary changes. I had the same issue with keeping the hourly data from Dark Sky up to date so I use the Variable Custom Component: https://github.com/rogro82/hass-variables
I built out a rather large array since I have several sensors in the table that need to be updated and then in automations.yml I define the variable as well as update it. That portion is at the bottom of this post. What you’ll see is that I do a few things:
  1. On HA start I trigger the variable to be updated
  2. I monitor one of the sensors (current apparent temp) and if it updates I trigger updating the variable
  3. Since #2 doesn’t always update I also update the variable every 30 minutes except between 11:30am and 5:30am just since I’m almost never looking at that data during that window.
event: start
- id: update-sensor-dark-sky
alias: update_sensor_dark_sky
platform: state
entity_id:
- sensor.dark_sky_apparent_temperature_0h
platform: time_pattern
minutes: ‘/30’
condition:
- after: ‘05:30:00’
before: ‘23:30:00’
condition: time
data_template:
value_template: “{{ as_timestamp(now()) }}”
attributes:
time:
- “{{ now().hour }}:00”
- “{{ (as_timestamp(now())+3600)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+36002)|timestamp_custom(’%H’) }}:00"
- "{{ (as_timestamp(now())+3600
3)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+36004)|timestamp_custom(’%H’) }}:00"
5)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+36006)|timestamp_custom(’%H’) }}:00"
7)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+36008)|timestamp_custom(’%H’) }}:00"
9)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360010)|timestamp_custom(’%H’) }}:00"
11)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360012)|timestamp_custom(’%H’) }}:00"
13)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360014)|timestamp_custom(’%H’) }}:00"
15)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360016)|timestamp_custom(’%H’) }}:00"
17)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360018)|timestamp_custom(’%H’) }}:00"
19)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360020)|timestamp_custom(’%H’) }}:00"
21)|timestamp_custom(’%H’) }}:00”
- “{{ (as_timestamp(now())+360022)|timestamp_custom(’%H’) }}:00"
23)|timestamp_custom(’%H’) }}:00”
- “{{ states.sensor.dark_sky_apparent_temperature_0h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_1h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_2h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_3h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_4h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_5h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_6h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_7h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_8h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_9h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_10h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_11h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_12h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_13h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_14h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_15h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_16h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_17h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_18h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_19h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_20h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_21h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_22h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_23h.state }}”
- “{{ states.sensor.dark_sky_apparent_temperature_24h.state }}”
cloud_coverage:
- “{{ states.sensor.dark_sky_cloud_coverage_0h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_1h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_2h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_3h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_4h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_5h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_6h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_7h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_8h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_9h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_10h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_11h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_12h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_13h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_14h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_15h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_16h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_17h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_18h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_19h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_20h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_21h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_22h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_23h.state }}”
- “{{ states.sensor.dark_sky_cloud_coverage_24h.state }}”
precip_probability:
- “{{ states.sensor.dark_sky_precip_probability_0h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_1h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_2h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_3h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_4h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_5h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_6h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_7h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_8h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_9h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_10h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_11h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_12h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_13h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_14h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_15h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_16h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_17h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_18h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_19h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_20h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_21h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_22h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_23h.state }}”
- “{{ states.sensor.dark_sky_precip_probability_24h.state }}”
summary:
- “<img src=”{{ states.sensor.dark_sky_summary_0h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_0h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_1h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_1h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_2h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_2h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_3h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_3h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_4h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_4h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_5h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_5h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_6h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_6h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_7h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_7h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_8h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_8h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_9h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_9h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_10h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_10h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_11h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_11h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_12h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_12h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_13h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_13h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_14h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_14h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_15h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_15h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_16h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_16h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_17h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_17h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_18h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_18h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_19h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_19h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_20h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_20h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_21h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_21h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_22h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_22h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_23h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_23h.state }}"
- “<img src=”{{ states.sensor.dark_sky_summary_24h.attributes.entity_picture }}" /> {{ states.sensor.dark_sky_summary_24h.state }}"
temperature:
- “{{ states.sensor.dark_sky_temperature_0h.state }}”
- “{{ states.sensor.dark_sky_temperature_1h.state }}”
- “{{ states.sensor.dark_sky_temperature_2h.state }}”
- “{{ states.sensor.dark_sky_temperature_3h.state }}”
- “{{ states.sensor.dark_sky_temperature_4h.state }}”
- “{{ states.sensor.dark_sky_temperature_5h.state }}”
- “{{ states.sensor.dark_sky_temperature_6h.state }}”
- “{{ states.sensor.dark_sky_temperature_7h.state }}”
- “{{ states.sensor.dark_sky_temperature_8h.state }}”
- “{{ states.sensor.dark_sky_temperature_9h.state }}”
- “{{ states.sensor.dark_sky_temperature_10h.state }}”
- “{{ states.sensor.dark_sky_temperature_11h.state }}”
- “{{ states.sensor.dark_sky_temperature_12h.state }}”
- “{{ states.sensor.dark_sky_temperature_13h.state }}”
- “{{ states.sensor.dark_sky_temperature_14h.state }}”
- “{{ states.sensor.dark_sky_temperature_15h.state }}”
- “{{ states.sensor.dark_sky_temperature_16h.state }}”
- “{{ states.sensor.dark_sky_temperature_17h.state }}”
- “{{ states.sensor.dark_sky_temperature_18h.state }}”
- “{{ states.sensor.dark_sky_temperature_19h.state }}”
- “{{ states.sensor.dark_sky_temperature_20h.state }}”
- “{{ states.sensor.dark_sky_temperature_21h.state }}”
- “{{ states.sensor.dark_sky_temperature_22h.state }}”
- “{{ states.sensor.dark_sky_temperature_23h.state }}”
- “{{ states.sensor.dark_sky_temperature_24h.state }}”
wind_bearing:
- “{{ states.sensor.dark_sky_wind_bearing_0h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_1h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_2h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_3h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_4h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_5h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_6h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_7h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_8h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_9h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_10h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_11h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_12h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_13h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_14h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_15h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_16h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_17h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_18h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_19h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_20h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_21h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_22h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_23h.state }}”
- “{{ states.sensor.dark_sky_wind_bearing_24h.state }}”
wind_speed:
- “{{ states.sensor.dark_sky_wind_speed_0h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_1h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_2h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_3h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_4h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_5h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_6h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_7h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_8h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_9h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_10h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_11h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_12h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_13h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_14h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_15h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_16h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_17h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_18h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_19h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_20h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_21h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_22h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_23h.state }}”
- “{{ states.sensor.dark_sky_wind_speed_24h.state }}”
Hi I’m looking to do something similar to this, but I see this is a rather old post.
Can you tell me if this code if for the old ‘states’ UI or the new ‘lovelace’ UI?
Anyone using this card with nordpool integration? :slight_smile:
this is what i got so far, don know how to get the time/hours to show up:
Looks like this card has been abandoned… Anyone find an alternative?
Why do you say that? Working fine for me.
Last updated Feb - 5 months ago…
Good to know. Reason I said that was because on the Github page it says “maintained: No! (As of 2020)”
Would you mind sharing your YAML for the screenshot you shared?
Try this:
          - type: entities
            title: Docker Containers
            show_header_toggle: false
            entities:
              - type: custom:fold-entity-row
                head:
                  type: section
                  label: Containers
                padding: 0
                entities:
                  - input_boolean.retrigger
                  - script.restartvscode
                  - switch.ha_dockermon_sabnzbd
                  - switch.ha_dockermon_sonarr
                  - switch.ha_dockermon_radarr
                  - switch.ha_dockermon_lazylibrarian
                  - switch.ha_dockermon_portainer
                    sort_by: name+
                    clickable: true
                    title: Docker Memory Now (MB)
                    entities:
                      include: sensor.*_memory
                    columns:
                      - name: Name
                        data: name
                      - name: Used Now
                        data: state
                    sort_by: name+
                    clickable: true
                    title: Docker Memory Average (MB)
                    entities:
                      include: sensor.*_memory_average
                    columns:
                      - name: Name
                        data: name
                      - name: Minimum
                        data: min_value
                      - name: Average
                        data: state
                      - name: Maximum
                        data: max_value
Hopefully iOS hasn’t mangled it…
