I would like to know if it is normal that my flic buttons only appears as entities and not as devices in integrations section, please ? And if you have the same message that says there is no uniqueID for those buttons ?
I believe that is normal, but it is not a concern. Is it?
I thought that they wasn’t appear as devices because they doesn’t have an uniqueID. If I use for example a Xiaomi switch, it appears as device and allow me to use it in automatisations with the different triggers: “press”, “hold”, “double clic”. So I wanted to do the same with Flic buttons but I now understand that I have to use a event here to catch those triggers. So it’s a bit different
