class MyClass:
def get_myFloatProperty(self):
return myFloatVariable;
In lovelace I can see the scary label “3.1500000953674316 W”. But really there is “3.15”. Mathematical rounding does not help, anyway there are undesirable effects like “3.14999999999999”. This is due to nature of float type.
How to control the display at the component level without templates?
Every entity has one and only one state, and it will be converted to a string, regardless of what type of value the state() method returns. So, let’s say your Entity-derived class has a _state attribute (like most do.) And let’s say it’s a float. Then your state() method could be:
class MyEntity(Entity):
"""My Entity."""
@property
def state(self):
"""Return the state of the entity."""
return f'{self._state:0.2f}'
Then it would always have two decimal digits.
If you want to have the full precision available to the user, then you could add that as an attribute. Or vice versa.
