At random times one of my Coolcam Zwave PIR sensors gives a lot of false motion detections. As you can see in the history diagram there are a few brown (green/red) bars where there are a lot of state changes. I am very sure there was not something that could trigger the sensor.
Below you can find the first and last part of the surrounded part (09:41 - 10:11). Does anyone have an idea what can cause these detections and how I can fix this?
Second question, can anyone explain how I can interpret the received data from the log? So what means “Received: 0x01, 0x0a, 0x00, 0x04” for example
thanks in advance
2019-11-07 08:32:48.918 Info, Node003, Received SensorBinary report: Sensor:12 State=Off
2019-11-07 08:32:48.918 Detail, Node003, Refreshed Value: old value=true, new value=false, type=bool
2019-11-07 08:32:48.918 Detail, Node003, Changes to this value are not verified
2019-11-07 08:32:48.918 Detail, Node003, Notification: ValueChanged
2019-11-07 09:41:24.579 Detail, Node005, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x05, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0xdd, 0x14
2019-11-07 09:41:24.579 Info, Node005, Received SensorMultiLevel report from node 5, instance 1, Luminance: value=221lux
2019-11-07 09:41:24.579 Detail, Node005, Initial read of value
2019-11-07 09:41:24.580 Detail, Node005, Notification: ValueChanged
2019-11-07 09:41:24.837 Detail, Node005, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x05, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x7c
2019-11-07 09:41:24.837 Info, Node005, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2019-11-07 09:41:24.837 Detail, Node005, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 09:41:24.837 Detail, Node005, Changes to this value are not verified
2019-11-07 09:41:24.838 Detail, Node005, Changes to this value are not verified
2019-11-07 09:41:24.838 Detail, Node005, Refreshed Value: old value=0, new value=8, type=byte
2019-11-07 09:41:24.838 Detail, Node005, Notification: ValueChanged
2019-11-07 09:41:24.851 Detail, Node005, Notification: ValueChanged
2019-11-07 09:41:24.871 Detail, Node005, Notification: ValueChanged
2019-11-07 09:41:24.887 Detail, Node005, Notification: ValueChanged
2019-11-07 09:41:24.903 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x30
2019-11-07 09:41:24.903 Info, Node005, Received SensorBinary report: Sensor:12 State=On
2019-11-07 09:41:24.903 Detail, Node005, Refreshed Value: old value=false, new value=true, type=bool
2019-11-07 09:41:24.903 Detail, Node005, Changes to this value are not verified
2019-11-07 09:41:24.904 Detail, Node005, Notification: ValueChanged
2019-11-07 09:43:16.781 Detail, Node005, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x05, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x01, 0x08, 0x61
2019-11-07 09:43:16.781 Info, Node005, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2019-11-07 09:43:16.781 Detail, Node005, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 09:43:16.782 Detail, Node005, Changes to this value are not verified
2019-11-07 09:43:16.782 Detail, Node005, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 09:43:16.782 Detail, Node005, Refreshed Value: old value=8, new value=0, type=byte
2019-11-07 09:43:16.782 Detail, Node005, Notification: ValueChanged
2019-11-07 09:43:16.794 Detail, Node005, Notification: ValueChanged
2019-11-07 09:43:16.803 Detail, Node005, Notification: ValueChanged
2019-11-07 09:43:16.811 Detail, Node005, Notification: ValueChanged
2019-11-07 09:43:16.841 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0x00, 0x0c, 0xcf
2019-11-07 10:09:40.750 Info, Node005, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2019-11-07 10:09:40.750 Detail, Node005, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 10:09:40.750 Detail, Node005, Changes to this value are not verified
2019-11-07 10:09:40.751 Detail, Node005, Changes to this value are not verified
2019-11-07 10:09:40.751 Detail, Node005, Refreshed Value: old value=0, new value=8, type=byte
2019-11-07 10:09:40.751 Detail, Node005, Notification: ValueChanged
2019-11-07 10:09:40.758 Detail, Node005, Notification: ValueChanged
2019-11-07 10:09:40.766 Detail, Node005, Notification: ValueChanged
2019-11-07 10:09:40.774 Detail, Node005, Notification: ValueChanged
2019-11-07 10:09:40.810 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x30
2019-11-07 10:09:40.811 Info, Node005, Received SensorBinary report: Sensor:12 State=On
2019-11-07 10:09:40.811 Detail, Node005, Refreshed Value: old value=false, new value=true, type=bool
2019-11-07 10:09:40.811 Detail, Node005, Changes to this value are not verified
2019-11-07 10:09:40.811 Detail, Node005, Notification: ValueChanged
2019-11-07 10:09:40.888 Detail, Node005, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x05, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0x78, 0xb1
2019-11-07 10:09:40.889 Detail,
2019-11-07 10:09:40.889 Info, Node005, Received SensorMultiLevel report from node 5, instance 1, Luminance: value=120lux
2019-11-07 10:09:40.889 Detail, Node005, Refreshed Value: old value=221, new value=120, type=decimal
2019-11-07 10:09:40.889 Detail, Node005, Changes to this value are not verified
2019-11-07 10:09:40.889 Detail, Node005, Notification: ValueChanged
2019-11-07 10:11:35.958 Detail, Node005, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x05, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x01, 0x08, 0x61
2019-11-07 10:11:35.959 Info, Node005, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2019-11-07 10:11:35.959 Detail, Node005, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 10:11:35.959 Detail, Node005, Changes to this value are not verified
2019-11-07 10:11:35.959 Detail, Node005, Refreshed Value: old value=8, new value=0, type=byte
2019-11-07 10:11:35.960 Detail, Node005, Notification: ValueChanged
2019-11-07 10:11:35.991 Detail, Node005, Notification: ValueChanged
2019-11-07 10:11:36.021 Detail, Node005, Notification: ValueChanged
2019-11-07 10:11:36.051 Detail, Node005, Notification: ValueChanged
2019-11-07 10:11:36.060 Detail, Node005, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x05, 0x04, 0x30, 0x03, 0x00, 0x0c, 0xcf
2019-11-07 10:11:36.063 Detail,
2019-11-07 10:11:36.063 Info, Node005, Received SensorBinary report: Sensor:12 State=Off
2019-11-07 10:11:36.063 Detail, Node005, Refreshed Value: old value=true, new value=false, type=bool
2019-11-07 10:11:36.063 Detail, Node005, Changes to this value are not verified
2019-11-07 10:11:36.064 Detail, Node005, Notification: ValueChanged
2019-11-07 10:13:32.958 Detail, Node003, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x03, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x7a
2019-11-07 10:13:32.958 Info, Node003, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2019-11-07 10:13:32.959 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2019-11-07 10:13:32.959 Detail, Node003, Changes to this value are not verified
2019-11-07 10:13:32.959 Detail, Node003, Refreshed Value: old value=0, new value=8, type=byte
2019-11-07 10:13:32.960 Detail, Node003, Notification: ValueChanged
2019-11-07 10:13:32.976 Detail, Node003, Notification: ValueChanged
2019-11-07 10:13:32.998 Detail, Node003, Notification: ValueChanged
2019-11-07 10:13:33.020 Detail, Node003, Notification: ValueChanged
2019-11-07 10:13:33.036 Detail, Node003, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x03, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x36
