Hello
I m looking for a flowmeter running with zigbee to detect the consumption of the hot water, soon the flowmeter detect the consumption i will start the heating of the water.
Best regards
Hello
Best regards
These most likely would not be happy on the hot water side, however perhaps will give you some ideas for a DIY system, if on the cold side. The LinkTap systems (overall) are for cold water gardens. I have been very happy with LinkTap as a garden solution. Their systems are not really designed for your application, however, again their products might give you some ideas. Their build quality is outstanding. I have no idea if you could create a custom converter for their Zigbee water valve with flow meter, however, again perhap will give you some ideas.
Good hunting!
You can place it on water heater inlet, cold side.
