Normally, when I try to validate my YAML for a new ESPHome device, I’ll run into an inevitable syntax error or something, fix it till it works, and then install the YAML on my ESP32 device. Today, something new has happened, and the validation fails repeatedly with the same error messages (this has persisted through a reboot, in case that might help). The error messages all refer to Python files that do the actually YAML validation. I have no clue how to fix this one. Reinstall ESPHome? If anyone has some suggestions on how to fix the issue, I’d love to hear your thoughts. Full log detail below:
INFO ESPHome 2025.3.3
INFO Reading configuration /config/esphome/esphome-web-f71094.yaml...
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 8, in <module>
sys.exit(main())
File "/esphome/esphome/__main__.py", line 1057, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 1035, in run_esphome
config = read_config(dict(args.substitution) if args.substitution else {})
File "/esphome/esphome/config.py", line 1095, in read_config
res = load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 949, in load_config
return _load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 939, in _load_config
return validate_config(config, command_line_substitutions)
File "/esphome/esphome/config.py", line 863, in validate_config
result.run_validation_steps()
File "/esphome/esphome/config.py", line 142, in run_validation_steps
task.step.run(self)
File "/esphome/esphome/config.py", line 562, in run
validated = schema(self.conf)
File "/esphome/esphome/voluptuous_schema.py", line 35, in __call__
res = super().__call__(data)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/schema_builder.py", line 281, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/validators.py", line 251, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/validators.py", line 379, in _exec
v = func(path, v)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/schema_builder.py", line 855, in validate_callable
return schema(data)
File "/usr/local/lib/python3.11/dist-packages/voluptuous/schema_builder.py", line 625, in validate_dict
return base_validate(path, data.items(), out)
File "/esphome/esphome/voluptuous_schema.py", line 149, in validate_mapping
cval = cvalue(key_path, value)
return schema(data)
File "/esphome/esphome/components/font/__init__.py", line 424, in font_file_schema
return validate_file_shorthand(value)
File "/esphome/esphome/components/font/__init__.py", line 405, in validate_file_shorthand
return font_file_schema(
File "/esphome/esphome/components/font/__init__.py", line 425, in font_file_schema
return TYPED_FILE_SCHEMA(value)
File "/esphome/esphome/config_validation.py", line 1630, in validator
value = Schema(schemas[key_v])(value)
v = func(path, v)
return schema(data)
File "/esphome/esphome/components/font/__init__.py", line 253, in add_local_file
FONT_CACHE[value] = path
File "/esphome/esphome/components/font/__init__.py", line 96, in __setitem__
self.store[self._keytransform(key)] = Face(str(value))
File "/usr/local/lib/python3.11/dist-packages/freetype/__init__.py", line 1192, in __init__
raise FT_Exception(error)
freetype.ft_errors.FT_Exception: FT_Exception: (unknown file format)
