Does anyone have a config for a sensor that displays the name of the last file written to a HA directory?
I am saving images with timestamps and and want the sensor to display the name of the last saved image.
Cheers
Cheers
you could write a command line sensor using a shell command similar to
ls -Art | tail -n 1
Thanks! I actually want to filter the return as I have 2 files produced on each capture (lastsnap and latest), and the file I care about is timestamped. I think I need grep
OK think I have it:
ls -Art | tail -n -3 | grep "capture.jpg"
Hmm on Hassio the following is raising an error from a command line sensor, although the command works when I ssh in:
- platform: command_line
command: ls share/motion -Art | tail -n -3 | grep "capture.jpg"
Does this variation help?
command: "ls share/motion -Art | tail -n -3 | grep 'capture.jpg'"
OK the following works, just a typo in the path:
command: "ls /share/motion -Art | tail -n -3 | grep 'capture.jpg'"
Cheers!
