In different guides I saw, that the font of the sidebar have changed, so it is possible, what am I doing wrong? I tried different fonts, but nothing have changed.
I can give a full code of the theme if it is necesarry.
I know, that theme’s font not applying for all cards, but I want to be sure, that it was applied for everything it can be.
When working with fonts on webpages you need to make sure that cache is either disabled or constantly cleared.
You also need to make sure your clients have the font, because fonts are not universal, so Arial might not be available on Android or Macs and it might be opposite with other fonts.
Thank you, I will notice this!
However… I see the font in some titles, so it is avaliable at least for PC. But when I cleared cache and reload webpage, font changed to Times New Roman:
Uhh, no… Just skipped that issue with sidebar and continued to fix the main part of interface. It was necessary to fix other cards with card mod manually.
