I’m having a problem saving an automation that I try to implement with for each loop.
YAML is the following:
alias: For Each Room
repeat:
for_each:
- room: Bedroom
status: sensor.bedroom_status
heating: climate.bedroom
cooling: climate.bedroom_ac
manual_hvac: switch.bedroom_hvac_manual_mode
manual_ac: switch.bedroom_ac_manual_mode
- room: Kitchen
status: sensor.kitchen_status
heating: climate.kitchen
manual_hvac: switch.kitchen_hvac_manual_mode
manual_ac: switch.kitchen_ac_manual_mode
- room: Livingroom
status: sensor.livingroom_status
heating: climate.livingroom
cooling: climate.livingroom_ac
manual_hvac: switch.livingroom_hvac_manual_mode
manual_ac: switch.livingroom_ac_manual_mode
- room: Office
status: sensor.office_status
heating: climate.office
cooling: climate.office_ac
manual_hvac: switch.office_hvac_manual_mode
manual_ac: switch.office_ac_manual_mode
sequence:
- if:
- condition: state
entity_id: switch.someone_home
state: "on"
alias: Someone is Home
then:
- alias: Turn On Heating if Room Status is not Alert
if:
- alias: Room Status is Not Alert
condition: not
conditions:
- condition: state
entity_id: "{{repeat.item.status}}"
state: Alert
alias: Room Status
then:
- alias: Turn On Heating if Manual Mode is Off
if:
- alias: Manual Mode Off
condition: state
entity_id: "{{repeat.item.manual_hvac}}"
state: "off"
then:
- service: climate.set_temperature
temperature: "{{states.input_select.hvac_manual_heat_temperature.state}}"
hvac_mode: heat
entity_id: "{{repeat.item.heating}}"
alias: Set Bedroom HVAC Temperature
else:
- alias: Turn Off Heating
if:
- condition: not
conditions:
- condition: state
state: "off"
alias: Heating is not Off
then:
service: climate.turn_off
data: {}
When I try to save, I get the error:
Message malformed: Entity {{repeat.item.status}} is neither a valid entity ID nor a valid UUID for dictionary value @ data[‘action’][0][‘else’][0][‘then’][0][‘then’][3][‘repeat’][‘sequence’][0][‘then’][0][‘if’][0][‘conditions’][0][‘entity_id’]
The YAML code you posted seems to be a script, not an automation. An automation has a trigger section, and an optional condition section.
A script looks like the example shown here. Note how the sequence: key appears immediately after the script’s name (it’s missing from your script example).
If your intention is to make an automation, not a script, then your example is missing a trigger section. I suggest you use the Automation Editor in visual mode to compose your automation. You can switch it to YAML mode to see the automation’s YAML code.
If your example is just a portion of an automation, please post the entire automation.
It is only a portion of the automation. In the meanwhile I managed to find another solution for the IF conditions. I used templates.
Please see the section below…
alias: For Each Room - Turn On Heating and Turn Off Cooling
repeat:
for_each:
- room: Bedroom
room_temperature: sensor.bedroom_temperature_sensor_temperature
x_fan: switch.bedroom_ac_xfan
- room: Kitchen
room_temperature: sensor.kitchen_temperature_sensor_temperature
- room: Livingroom
room_temperature: sensor.livingroom_temperature_sensor_temperature
x_fan: switch.livingroom_ac_xfan
- room: Office
room_temperature: sensor.office_temperature_sensor_temperature
heating: climate. Office
x_fan: switch.office_ac_xfan
sequence:
- alias: Turn On Heating and Turn Off Cooling
if:
- condition: state
state: "on"
then:
- alias: Turn On Heating System and Turn Off AC
if:
- condition: template
value_template: "{{states(repeat.item.status) != \"Alert\" }}"
alias: Room Status is not Alert
then:
if:
value_template: "{{states(repeat.item.manual_hvac) == \"off\"}}"
alias: Heating Manual Mode is OFF
then:
hvac_mode: heat
alias: Set Heating Temperature
- alias: Turn Off AC
if:
value_template: "{{states(repeat.item.manual_ac) == \"off\"}}"
alias: AC Manual Mode is Off
value_template: "{{states(repeat.item.cooling) != \"off\"}}"
alias: AC is not Off
then:
- service: switch.turn_on
data: {}
entity_id: "{{repeat.item.x_fan}}"
alias: Turn On XFan
- service: climate.turn_off
data: {}
entity_id: "{{repeat.item.cooling}}"
alias: Turn Off AC
else:
- alias: Turn Off Heating System
if:
value_template: "{{states(repeat.item.heating) != \"off\"}}"
alias: Heating is not OFF
then:
data: {}
if:
then:
data: {}
alias: Turn On XFan
data: {}
alias: Turn Off AC
else:
if:
then:
if:
then:
temperature: 18
hvac_mode: heat
alias: Set Heating Temperature to 18 Degrees
if:
then:
data: {}
alias: Turn On XFan
data: {}
alias: Turn Off AC
else:
if:
then:
data: {}
if:
then:
data: {}
alias: Turn On XFan
data: {}
alias: Turn Off AC
In the future, please indicate that in your first post or supply the entire automation. Otherwise we don’t have a clear picture of what the example represents.
For future reference, a State Condition doesn’t support templates. That’s why both of these State Conditions are invalid.
- condition: state
state: Alert
alias: Room Status
condition: state
state: "off"
That’s why it was necessary to convert them to Template Conditions.
In addition, you should avoid using direct references to an entity’s state value like this:
