Forbidden 403 error message when opening the app (pc and smartphone)
Currently, I have the problem on the smartphone and no longer on the PC. However, this keeps changing…
It works When i connect to the IP in my Wi-Fi → IT doesnt work When i connect from my wifi to the external Adress. The app has already been deleted and the smartphone restarted.
Im using Cloudflare and i’m admin.
  • Core2025.4.1
  • Supervisor2025.03.4
  • Operating System15.1
  • Frontend20250404.0
Hi, did it work at all previously to connect using your WAN (external) address when on your LAN (connected to your home Wi-Fi)?
Also, you can specify both your WAN & LAN address in the mobile companion app.
