I’ve been using Python scripts to do some of my advanced automations, but was really getting frustrated by not being allowed to import libraries.
Then I found a mention of AppDaemon here on the forum. Since then, life is good.
This AppDaemon app checks to see if a new version of Home Assistant has been released, and then has Alexa notify of the good news.
For this to work, you will need to install the Notify Me skill. You will also need to register for an Access Code which will be used to authenticate Home Assistant.
Next, you will need to configure two custom sensors in your configuration.yaml
file.
- platform: version
name: Installed HA Version
source: local
- platform: version
name: Available HA Version
source: pypi
Next is to get AppDaemon installed. Go read this. Spoiler: The instructions for installing AppDaemon are at the very bottom.
There is some tweaking necessary, as the documentation is somewhat out-of-date. Below is my appdaemon.yaml
. (If you copy and paste this, note that my ha_url
uses HTTPS, not HTTP. Don’t let that one letter trip you up.)
secrets: /home/homeassistant/.homeassistant/secrets.yaml
appdaemon:
logfile: STDOUT
errorfile: STDERR
log_generations: 3
threads: 10
latitude: [REDACTED]
longitude: [REDACTED]
elevation: [REDACTED]
time_zone: America/Chicago
plugins:
HASS:
type: hass
ha_url: https://127.0.0.1:8123
token: !secret appdaemon_token
cert_verify: false
Here is my apps.yaml
version_monitor:
module: version_monitor
class: VersionMonitor
And here is version_monitor.py
import appdaemon.plugins.hass.hassapi as hass
import datetime
import json
import requests
class VersionMonitor(hass.Hass):
def initialize(self):
self.ver_installed = self.get_state('sensor.installed_ha_version')
self.ver_available = self.get_state('sensor.available_ha_version')
self.update_time = datetime.time(18, 0, 0)
self.alexa_notify_secret = '[REDACTED]'
self.has_been_announced = False
self.ver_monitor = self.run_daily(self.report_new_version, self.update_time)
def report_new_version(self, kwargs):
if self.ver_installed == self.ver_available:
return
if self.has_been_announced:
return
alert_msg = 'A new version of Home Assistant is available. {} has been released.'.format(self.ver_available)
body = json.dumps({'notification': alert_msg, 'accessCode': self.alexa_notify_secret})
requests.post(url="https://api.notifymyecho.com/v1/NotifyMe", data=body)
self.has_been_announced = True
If someone figures out how to access your secrets file from within the app, please let me know!
I hope you enjoy this little app. I especially hope that this introduces someone to AppDaemon. I know I wish I found it much sooner than I did.
