Ok, I’ll shut up then
There is a new kind of card available : Results.
Check it out!
Fabulous!!!
Added in 0.5.0 , the countdown card!
It doesn’t work for me
is there any way to use the countdown card to start an automation ? Like, 1 hour before the race.
same here, getting the same error. I’m running version 0.5 My apologies. I was still running 0.35, HACS showed the available version.
Now it works.
0.5.0 works fine here.
Hi, Is it possible to merge the last_result and results cards and display the last race results automatically in the results card?
Yeah probably. Let me try and fix that for you
HACS caches a lot. Force the update by using “Update information”
Unfortunately no, because its a frontend card it can’t be used like that. Well it can with a sort of hack but not in a realiable way.
What you CAN do is use this Formula One Card - #91 by marcokreeft87 and use that sensor to trigger an automation
Check out v0.5.1 @ValMarDav. Last result card is kinda obsolete now, but I will still keep it in for the people who use it
Can you share your yaml?
Here’s the yaml, but it’s a page designed for use in the Dwains dashboard. It will require adjustments to work without the dashboard.
Got it like this now
cards:
- type: vertical-stack
cards:
- type: custom:formulaone-card
card_type: countdown
date_locale: nl
card_type: next_race
title: Next Race
date_locale: nl
image_clickable: true
cards:
- type: custom:tabbed-card
options: {}
tabs:
- card:
card_type: results
date_locale: nl
location_clickable: true
attributes:
icon: mdi:view-list
- card:
card_type: schedule
date_locale: nl
previous_race: hide
attributes:
icon: mdi:calendar
- card:
card_type: constructor_standings
attributes:
icon: mdi:car-brake-abs
- card:
card_type: driver_standings
standings:
show_flag: true
show_team: true
attributes:
icon: mdi:racing-helmet
That’s fine, I didn’t know the tabbed-card card. Less code to do the same thing.
Oeh, I love how it looks with the tabbed card!
Feat request: would it be possible to also have the team icons in the constructors overview, just like the flag of the driver?
And possible, configurable, also in the other overviews?
