GD all,
I am trying to setup my foscam cameras. I have 2 of them, one is fixed, the other is also ptz.
I can see both video streams on my HA dashboard.
Then I followed https://www.home-assistant.io/integrations/foscam/ to setup the ptz.
However, after that nothing happens.
So I checked the service in the developer tools, and started the service manually, but also nothing.
What could I be misising here?
(sing hass.io 108.9 by the way)
Arno
Got the same issue as well. my FOSCAM camera supports PTZ, but it will not respond to the ptz code as supplied.
Anyone else having the same problem, and have resolved the issue? any tips will be great.
I managed to get it working. I had created a user account on the camera with visotor rights. Apparently a visitor cannot control the ptz. After re-creating the user as operator all started work. Except there is a huge lag in the control. It takes 1 or 2 secs before you see the movement of the camera. Not sure if that is a workable speed.
Cheerz Arno
