Foxess to HA integration help
Foxes integration into Home Assistant
HA green (had it a week)
Detached garage Foxess H1 5kW hybrid inverter and 12.5kWh of Batteries
House Foxess H1 5kW hybrid inverter and 5.6kW solar
Hi there,
I’m a complete novice at this malarkey.
I appear to have managed to install and integrate everything okay except, perhaps, Foxess?…
When I integrated foxes by the API route, I expected two devices (one for each inverter) to appear in HA green’s overview, each with 39 attributes. What I actually got was one device (?) called ‘Sensor’ with 138 attributes.
Should it be as it is or as I expected? Have I made a miss-step in the integration process (if so, any idea what I’ve done wrong?), or do I appear to have done it correctly?
I’m gonna post this on both the HA and Foxess forums
Many thanks in advance,
John
