Frankever IR Baster (Tuya based) config
Hi, I bought this Frankever IR blaster from uncle Ali. This one does not support Tuya-convert (due to newer firmware), but it’s quit easily converted to esphome home if you are able to solder a few dupont wires.
More on that on our website espthings.io
The config:
substitutions:
  devicename: esp_ir_01
  upper_devicename: ESP IR - 01"
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: !secret esphome_wifi_ssid
  password: !secret esphome_wifi_password
  power_save_mode: high
  ap:
    ssid: $devicename
    password: !secret esphome_ap_password
captive_portal:
api:
  password: !secret esphome_api_password
ota:
  password: !secret esphome_ota_password
logger:
web_server:
  port: 80
# GPIO	Component	Description
# 04	LED1i (52)	Blue LED - Link status
# 05	IRrecv (51)	IR Receiver
# 13	Button1 (17)	Button
# 14	IRsend (8)	IR Transmitter
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 30%
remote_receiver:
  pin:
    number: GPIO5
    inverted: True
  tolerance: 55%
  dump: all
climate:
  - platform: daikin
    name: "$upper_devicename Living AC"
    receiver_id: rcvr
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      - logger.log: "$upper_devicename button pressed"
output:
  - platform: esp8266_pwm
    pin:
      number: GPIO4
      inverted: false
light:
  - platform: monochromatic
    name: "$upper_devicename Blue LED"
    output: esphome_ir1_led
Any guidance?
Sure, right below the picture :wink:
