Freeze esp32?
Hello everyone, I have two esp32 programmed to read data from 2 victron. They have always worked perfectly, but today one had stopped in the screen that I attach and did not go on … I turned off the esp32 and it worked. It had never happened to me, is it norm
al that this can happen?
A black swan event perhaps.
Explain yourself better. Thank you
The black swan theory or theory of black swan events is a metaphor that describes an event that comes as a surprise, has a major effect, and is often inappropriately rationalized after the fact with the benefit of hindsight. The term is based on a Latin expression which presumed that black swans did not exist. The expression was used until around 1697 when Dutch mariners saw black swans living in Australia.
I thank you because you made me smile. But you didn’t answer technically.
strong text:stuck_out_tongue_winking_eye:
Esp32 do from time do stop working. Some will run for months to years and others will crash daily. Power. Programing, bad batches, random particles… can all be factors.
