Frequent changes of value z-wave device
For some time I have frequent changes for one of my z-wave Nodes.
From OZW_Log.txt:
2018-10-11 16:59:22.778 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.3W
2018-10-11 16:59:22.778 Detail, Node009, Refreshed Value: old value=0.4, new value=0.3, type=decimal
2018-10-11 16:59:22.778 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:22.778 Detail, Node009, Notification: ValueChanged
2018-10-11 16:59:24.777 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x04, 0xee
2018-10-11 16:59:24.777 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.4W
2018-10-11 16:59:24.777 Detail, Node009, Refreshed Value: old value=0.3, new value=0.4, type=decimal
2018-10-11 16:59:24.777 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:24.778 Detail, Node009, Notification: ValueChanged
2018-10-11 16:59:30.777 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x03, 0xe9
2018-10-11 16:59:30.777 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.3W
2018-10-11 16:59:30.777 Detail, Node009, Refreshed Value: old value=0.4, new value=0.3, type=decimal
2018-10-11 16:59:30.777 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:30.777 Detail, Node009, Notification: ValueChanged
2018-10-11 16:59:31.777 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x04, 0xee
2018-10-11 16:59:31.777 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.4W
2018-10-11 16:59:31.778 Detail, Node009, Refreshed Value: old value=0.3, new value=0.4, type=decimal
2018-10-11 16:59:31.778 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:31.778 Detail, Node009, Notification: ValueChanged
2018-10-11 16:59:44.779 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x03, 0xe9
2018-10-11 16:59:44.779 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.3W
2018-10-11 16:59:44.779 Detail, Node009, Refreshed Value: old value=0.4, new value=0.3, type=decimal
2018-10-11 16:59:44.780 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:44.780 Detail, Node009, Notification: ValueChanged
2018-10-11 16:59:45.779 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x04, 0xee
2018-10-11 16:59:45.779 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Power: value=0.4W
2018-10-11 16:59:45.780 Detail, Node009, Refreshed Value: old value=0.3, new value=0.4, type=decimal
2018-10-11 16:59:45.780 Detail, Node009, Changes to this value are not verified
2018-10-11 16:59:45.780 Detail, Node009, Notification: ValueChanged
As a result OZW_Log.txt grows enormously as well as hass_db (because of state changes).
Greetings,
M
If it isn’t something you want to track, exclude it from your recorder, history, and logbook.
As for the OZW_Log.txt you can modify options.xml to turn off logging or change the log level:
<Options xmlns='http://code.google.com/p/open-zwave/'>
  <Option name="logging" value="true" />
  <Option name="SaveLogLevel" value="4" />
  <Option name="Associate" value="true" />
  <Option name="NotifyTransactions" value="false" />
  <Option name="DriverMaxAttempts" value="0" />
  <Option name="SaveConfiguration" value="true" />
</Options>
The Following Values can be used for the various LogLevel options above. Use the numeric value in options.xml to specify the actual log level.
value Logging Level
0 No Logging
1 All Messages
2 Fatal Messages Only
3 Error Messages and Higher
4 Warning Messages and Higher
5 Alert Messages and Higher
6 Info Messages and Higher
7 Detailed Messages and Higher
8 Debug Messages and Higher
9 Protocol Information and Higher
Source: https://github.com/OpenZWave/open-zwave/wiki/Config-Options
Thank you for suggesion.
Actually I prefer to have the same LogLevel for my z-wave devices. I have about 10 different z-wave devices (thermostats and wall plugs) and all of them worked simillar (and logged their state changes on predictable level).
For some time one of my z-wave wall plugs (Fibaro) started to raport (very frequent) value changes:
from 0,4W to 0,3W… and… again from 0.3W to 0.4W… and vice-versa.
I wondering what to do. Is there some global setting to reduce sensibility of state changes for particular z-wave devices?
Regards, M.
Check the Zwave options for your plugs, if there isn’t one, then likely there’s no way to resolve that.
