I’ve recently migrated my HA instance from a very old NUC to a RPi5, and I’ve found that the HA core is segfaulting on startup most of the time. Once it starts, it’s generally fine, but it’s just a problem on startup.
Things I’ve tried:
- Changing the PSU and power cable.
- Checking for underpower events with
vcgencmd get_throttled. (There are none.) - Checking the fan. (It’s working.)
- Changing the SD card.
- Reflashing the SD card / changing the OS (same issue happens on Bookworm, Trixie and HAOS 16.3).
- Changing the network device. (Happens when both connected to wifi and ethernet.)
- Running in debug mode
- Running in safe mode
Every time I get this in the HA log:
s6-rc: info: service legacy-services successfully started
2025-11-30 15:07:58.717 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-11-30 15:07:58.781 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=167 from 2025-11-30 15:06:32.327707)
[15:08:03] INFO: Home Assistant Core finish process exit code 256
[15:08:03] INFO: Home Assistant Core finish process received signal 11
And a home-assistant.log.fault with the following contents:
Fatal Python error: Segmentation fault
Thread 0x0000007f88bfe3b8 (most recent call first):
File "/usr/local/lib/python3.13/site-packages/pycares/__init__.py", line 348 in _run_safe_shutdown_loop
File "/usr/local/lib/python3.13/threading.py", line 994 in run
File "/usr/local/lib/python3.13/threading.py", line 1043 in _bootstrap_inner
File "/usr/local/lib/python3.13/threading.py", line 1014 in _bootstrap
Thread 0x0000007f8a3fe3b8 (most recent call first):
File "/usr/local/lib/python3.13/threading.py", line 359 in wait
File "/usr/local/lib/python3.13/concurrent/futures/_base.py", line 451 in result
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 665 in _wait_startup_or_shutdown
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 765 in _run
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 677 in run
Current thread 0x0000007f8ff7e3b8 (most recent call first):
File "<frozen importlib._bootstrap>", line 488 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 1321 in create_module
File "<frozen importlib._bootstrap>", line 813 in module_from_spec
File "<frozen importlib._bootstrap>", line 921 in _load_unlocked
File "<frozen importlib._bootstrap>", line 1331 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1360 in _find_and_load
File "<frozen importlib._bootstrap_external>", line 1329 in exec_module
File "<frozen importlib._bootstrap>", line 935 in _load_unlocked
File "/usr/local/lib/python3.13/site-packages/av/filter/__init__.py", line 1 in <module>
File "<frozen importlib._bootstrap_external>", line 1027 in exec_module
File "<frozen importlib._bootstrap>", line 1310 in _find_and_load_unlocked
File "/usr/local/lib/python3.13/site-packages/av/__init__.py", line 10 in <module>
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 238 in set_pyav_logging
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59 in run
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 93 in _worker
Thread 0x0000007f90b723b8 (most recent call first):
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 90 in _worker
Thread 0x0000007f90c763b8 (most recent call first):
Thread 0x0000007f90d7a3b8 (most recent call first):
Thread 0x0000007f90e7e3b8 (most recent call first):
Thread 0x0000007f9177e3b8 (most recent call first):
File "<frozen importlib._bootstrap_external>", line 1218 in get_data
File "<frozen importlib._bootstrap_external>", line 1119 in get_code
File "<frozen importlib._bootstrap_external>", line 1023 in exec_module
File "<frozen importlib._bootstrap>", line 1387 in _gcd_import
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88 in import_module
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201 in protected_loop_func
File "/usr/src/homeassistant/homeassistant/loader.py", line 1066 in _get_component
Thread 0x0000007f925ea3b8 (most recent call first):
Thread 0x0000007f926ee3b8 (most recent call first):
File "/usr/local/lib/python3.13/logging/handlers.py", line 1539 in dequeue
File "/usr/local/lib/python3.13/logging/handlers.py", line 1593 in _monitor
Thread 0x0000007f9ee44020 (most recent call first):
File "/usr/local/lib/python3.13/selectors.py", line 452 in select
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2012 in _run_once
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683 in run_forever
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712 in run_until_complete
File "/usr/src/homeassistant/homeassistant/runner.py", line 289 in run
File "/usr/src/homeassistant/homeassistant/__main__.py", line 215 in main
File "/usr/src/homeassistant/homeassistant/__main__.py", line 229 in <module>
File "<frozen runpy>", line 88 in _run_code
File "<frozen runpy>", line 198 in _run_module_as_main
Extension modules: _cffi_backend, ciso8601, yaml._yaml, propcache._helpers_c, ulid_transform._ulid_impl, multidict._multidict, yarl._quoting_c, markupsafe._speedups, _brotli, backports.zstd._zstd, aiohttp._http_writer, aiohttp._http_parser, aiohttp._websocket.mask, aiohttp._websocket.reader_c, frozenlist._frozenlist, annotatedyaml.reference, annotatedyaml.constructors, _awscrt, charset_normalizer.md, simplejson._speedups, requests.packages.charset_normalizer.md, requests.packages.chardet.md, regex._regex, dbus_fast.signature, dbus_fast._private.marshaller, dbus_fast.message, dbus_fast.service, dbus_fast._private.address, dbus_fast.unpack, dbus_fast.message_bus, dbus_fast._private.unmarshaller, dbus_fast.aio.message_reader, habluetooth.models, habluetooth.advertisement_tracker, bluetooth_data_tools.gap, bluetooth_data_tools._time_impl, bluetooth_data_tools._utils_impl, bluetooth_data_tools.utils, habluetooth.scanner, habluetooth.channels.bluez, habluetooth.manager, habluetooth.base_scanner, zeroconf._utils.time, zeroconf._dns, zeroconf._protocol.outgoing, zeroconf._protocol.incoming, zeroconf._cache, zeroconf._record_update, zeroconf._history, zeroconf._updates, zeroconf._services, zeroconf._utils.ipaddress, zeroconf._services.info, zeroconf._services.registry, zeroconf._handlers.answers, zeroconf._handlers.multicast_outgoing_queue, zeroconf._handlers.query_handler, zeroconf._handlers.record_manager, zeroconf._listener, zeroconf._services.browser, sqlalchemy.cyextension.collections, sqlalchemy.cyextension.immutabledict, sqlalchemy.cyextension.processors, sqlalchemy.cyextension.resultproxy, sqlalchemy.cyextension.util, greenlet._greenlet, fnv_hash_fast._fnv_impl, PIL._imaging, isal.igzip_lib, isal.isal_zlib, numpy._core._multiarray_umath, numpy.linalg._umath_linalg, cached_ipaddress.ipaddress, audioop._audioop, av._core, av.logging, av.bytesource, av.buffer, av.audio.format, av.enum, av.error, av.utils, av.option, av.descriptor, av.container.pyio, av.dictionary, av.format, av.stream, av.container.streams, av.sidedata.motionvectors, av.sidedata.sidedata, av.opaque, av.packet, av.container.input, av.container.output, av.container.core, av.codec.context, av.video.format, av.video.reformatter, av.plane, av.video.plane, av.video.frame, av.video.stream, av.codec.codec, av.frame, av.audio.layout, av.audio.plane, av.audio.frame, av.audio.stream, av.audio.codeccontext, av.filter.filter, av.filter.graph, av.filter.context, av.filter.link (total: 114)
Odd thing: when it’s upstairs and the HDMI port is attached to the TV, it segfaults maybe half the time. When it’s downstairs and headless, it segfaults every time.
