Fresh install HA supervised in docker unsupported can I fix it in this way?
Hi all.
I freshly installed in Nuc Debian 11 + Home assistant supervised in docker.
In the same system I run cumulus directly in Debian .
Frigate is active as Home assistant addon + coral and it works great.
I checked system health and I have 3 problems.
  • docker_configuration
  • os_agent]
  • systemd_resolved
Can I resolve these problems following the linked tutorial without the risk of screwing my installation?
The system works perfectly, which is the risk of running an unsupported installation?
Thank you
You really should fix these problems. It is not difficult, and won’t cause problems.
Thanks, I followed your suggestion and fixed it without a problem. Thank you
