Fresh install not finding network interface
I’m trying to install HAOS on a SuperMicro-based machine. Ubunto runs fine, and can download the HAOS restore image using Firefox without any issues. I use “disks” to restore the image to the primary HDD on the machine, and then reboot.
I get this:
Welcome to the Home Assistant command line.
Waiting for Supervisor to startup...
System information
  OS Version:               Home Assistant OS 15.2
  Home Assistant Core:      landingpage
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
Networking wise, the machine is ethernet wired to a switch, which is ethernet wired to a router. The machine has a Baseboard Management Controller (BMC) which works fine, and is how i can work with the console.
I don’t see the machine from the admin page on my router (other than the BMC), and I don’t get a connection into homeassistant.local:8123, so I tried
ha > network info
docker:
  address: 172.30.32.0/23
  dns: 172.30.32.3
  gateway: 172.30.32.1
  interface: hassio
host_internet: false
interfaces: []
supervisor_internet: false
I suspect that the issue is to do with the network interfaces on the machine. Does HAOS expect there to be an eth0? From Ubuntu :
ubuntu@ubuntu: $ netstat -i
Kernel Interface table
Iface             MTU    RX-OK RX-ERR RX-DRP RX-OVR   TX-OK TX-ERR TX-DRP TX-OVR Flg
eno1             1500    23086      0   3302 0          912      0      0      0 BMRU
eno2             1500    20084      0   3300 0            0      0      0      0 BMRU
eno3             1500    20063      0   3296 0            0      0      0      0 BMRU
eno4             1500    20072      0   3298 0            0      0      0      0 BMRU
lo              65536      191      0      0 0          191      0      0      0 LRU
ubuntu@ubuntu:~$
So the machine has 4 physical ethernet ports, eno1 to eno4
Also, with HAOS booted I get
# nmcli dev show
GENERAL.DEVICE:                         lo
GENERAL.TYPE:                           loopback
GENERAL.HWADDR:                         00:00:00:00:00:00
GENERAL.MTU:                            65536
GENERAL.STATE:                          100 (connected (externally))
GENERAL.CONNECTION:                     lo
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/1
IP4.ADDRESS[1]:                         127.0.0.1/8
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         ::1/128
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         docker0
GENERAL.TYPE:                           bridge
GENERAL.HWADDR:                         FE:A1:90:0C:F3:E8
GENERAL.MTU:                            1500
GENERAL.STATE:                          10 (unmanaged)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
IP4.ADDRESS[1]:                         172.30.232.1/23
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.30.232.0/23, nh = 0.0.0.0, mt = 0
IP6.ADDRESS[1]:                         fe80::fca1:90ff:fe0c:f3e8/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = fe80::/64, nh = ::, mt = 256
GENERAL.DEVICE:                         hassio
GENERAL.HWADDR:                         B2:DB:72:AA:AA:EB
GENERAL.MTU:                            1500
IP4.ADDRESS[1]:                         172.30.32.1/23
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.30.32.0/23, nh = 0.0.0.0, mt = 0
IP6.ADDRESS[1]:                         fe80::b0db:72ff:feaa:aaeb/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         veth04bbe05
GENERAL.TYPE:                           ethernet
GENERAL.HWADDR:                         BE:AF:DF:13:0A:58
GENERAL.MTU:                            1500
WIRED-PROPERTIES.CARRIER:               on
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::bcaf:dfff:fe13:a58/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         veth0d7c559
GENERAL.HWADDR:                         06:BA:DD:4F:9B:74
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::4ba:ddff:fe4f:9b74/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         veth555eec3
GENERAL.HWADDR:                         06:59:0C:E0:C7:74
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::459:cff:fee0:c774/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         veth679ebef
GENERAL.HWADDR:                         86:01:21:2F:D7:98
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::8401:21ff:fe2f:d798/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         veth6e2c7cb
GENERAL.HWADDR:                         56:01:1A:75:21:09
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::5401:1aff:fe75:2109/64
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         vethba33ba2
GENERAL.HWADDR:                         4A:54:FC:35:AD:5C
GENERAL.MTU:                            1500
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         fe80::4854:fcff:fe35:ad5c/64
IP6.GATEWAY:                            --
Can you help? Am I barking up the wrong tree entirely? (quite possible)
Thanks for any help you can give.
I am having a very similar issue.
Bare metal install, when booting into an Ubuntu flash drive, I see my physical interface (ens5f5) and receive a proper internet connection through it.
When booting into HAOS, it doesn’t see that interface at all. And my nmcli dev show looks similar (with no physical interface).
My problem is that I don’t know what I should expect to see from nmcli. Should I be able to see physical network interfaces?
So that I can try to follow this up further, can anybody who has a working HAOS share the output of “nmcli dev show”?
To get there, I start at the console :
System information
ha >
at this point, I can press ctrl-alt-F2 on the console to bring this up:
Welcome to Home Assistant
homeassistant login:
I type in “root” (no quotes) and there is no password
it responds with:
Welcome to Home Assistant OS.
Use `ha` to access the Home Assistant CLI.
Now I type in “nmcli dev show” (no quotes)
I know it’s a bit rude to bump my question, but I’m just stuck :frowning:
Can anyone shed any light on this?
I had a spot of spare time over Christmas, so I thought I’d have another go at this. I see that there is a newer version of HomeAssistant (OS 16.3) so I gave that a go and HEY PRESTO!!! IT WORKS
Just to confirm : I installed the latest Ubunto onto a 16GB USB thumb drive, and booted my spare X86/64 microserver from that (using TRY, not INSTALL). I then browsed to https://github.com/home-assistant/operating-system/releases/download/16.3/haos_generic-x86-64-16.3.img.xz and saved that in downloads
I then ran the “disks” program in Ubuntu and selected the target hard disk, then the source image I had just downloaded, and “restored” the image to the hard disk. I then rebooted the server, selecting the hard disk as the boot source. It took a few moments to get going, and I (so far) have to use the <ipAddress>:8128 rather than homeassistant.local:8123, but it’s working. The ipaddress is shown when the HomeAssistant server starts up, so it’s not too bad.
AHA!
I found that in my network, I have to use homeassistant:8123 (without th .local bit)
