Fresh install, Server&Download not starting
Literally pulling my hair out right now.
Just flashed hass.io v1.0 using etcher onto an sdcard, connected the previously tested Ethernet cable and a monitor(just in case), and plugged it in. I checked ~1hr later, and nothing was coming up on hassio.local:8123, nor on the monitor. no errors, nada, null.
Also SD cards are the bane of my existence especially when there are multiple partitions. For some reason, none of my computers want to open the formatter (gparted, windows disk management). Note they worked fine before flashing.
I have no idea where to go from here. Anyone have any leads? Also unless i’m missing something on the reformat thing, i’m down a card every time I try this.
What i’m working with :
Rpi 3
32gb sd card / 16 gb sd card
Arch Linux & Windows 10
Network: 100mbps up/down
Longshot but did you try going to your IP address:8123? rather than hassio.local:8213 (ie 192.168.1.XXX:8213)
hassio.local would not resolve for me but the IP address did.
It worked, Thanks!
